Heart rate sensor MAX30102 - Page 3
Page 3 of 3 FirstFirst 123
Results 81 to 85 of 85
  1. #81
    Default Re: Heart rate sensor MAX30102
    I think the LPF should not be so aggressive.
    if you want automatic pulse measurement that remains to be seen, a pretty picture is a different story
    you can adjust filter as you see fit
    the filter is not really the issue, its the variability of the data that is problematical, every 128 sample is subtly different.
    light leakage, finger pressure and position and even finger compression time lead to wildly variable readings. my max30102 housing is probable not ideal either
    i use for this filter
    fv = fv*x + nv*(y)
    where x+y = 1, fv = average nv = new value
    in pbp terms x y
    ave = (ave ** 60000) + (buffer[index] ** 5535 ) ;60000 + 5535 = 65535
    or
    ave = (ave */ 250) + (buffer[index] */ 5 ) ;250+ 5 = 255
    depending on finesse required, the introduced phase shift has no bearing on the result either.
    it may not be as fast as your method but has better control and in this case speed is of no importance
    @ PutMulResult?D _average ;RED AVERAGE
    ave = DIV32 128 ;RED AVERAGE
    reg = OVF_COUNTER
    i2cread sda,scl,ADDR,reg,[reg ]
    DEBUG 13,10,"OverFlows ",DEC reg,9,dec ave,9,hex ave
    FOR index = 0 TO 255 step 2
    ave = (ave ** 57000) + (buffer[index] ** 8535 )
    lpfdata[index>>1]=ave
    ;.....lpf..;;;;----red-----;;;;======-ir-========
    DEBUG 13,10,dec ave,9,dec buffer[index],9,dec buffer[index+1]
    NEXT
    ' RETURN
    Oct 2010
    sorry for my late response. I was really busy these days.
    thanks for the info. I will do some changes and tests.
  3. #83
    I do not know if it is suitable for this project, but I had good results with Darrels Taylor ADC oversampling routines (http://dt.picbasic.co.uk/CODEX/AnalogueOverSampling).
    Also Kalman filters maybe of use. I find them difficult to implement though.
    no amount of low pass filtering will remove the dc component, ultimately it just makes it worse.
    the dc component needs to be removed to make detection of the beat peaks reliable.
    there is plenty of raw data posted, you can always ask for more. feel free to have a go
    I am not currently on this project. Was disappointed and set it aside. Removing DC component with firmware I think is too difficult.
    The oversampling of DT routines were tested and applied on other projects with amazing results (costing in program speed of course, nothing is free).
  1. New PIC failure rate
    By timmers in forum General
    Last Post: - 26th March 2009, 12:11
  2. Rf module baud rate
    By tazntex in forum Serial
    Last Post: - 5th August 2008, 18:47
  3. Replies: 6
    Last Post: - 18th January 2008, 08:17
  4. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 23:42
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:10
