Digital touch Screen Combination lock
Results 1 to 40 of 42
    Default Re: Digital touch Screen Combination lock
    As this statement, how could we read the status of the actual pin without using the port as input. Could you please explain to me the method?
    simply put you cannot , reading portx is the only direct way to read the actual status of the pins.
    what henrik means is why would you read a port to read the value of outputs you have already set. the outputs will be at the level you set them to
    (after a suitable interval to allow pin to settle) {providing load is acceptable}.
    what are trying to do ?
    do you mean something like this
    no need to wear out the eeprom
    ANSELA = 0
        DEFINE OSC 64
        OSCCON = $70
        OSCTUNE.6 = 1
        TRISA = %11111100
    led1 var porta.0    ; alias led1 to porta.0
    led2 var porta.1    ; alias led2 to porta.1
    x    var bit            ; tried to use X var as a bit in order to hold the value of the actual status of the pin.
    x = 0                  ; we write 0 to var X
    loopy:
    lata.0 = 1           ; we write 1 to lata.0
    gosub holdmem  ; gosub to holdmem
    led2  = x      ; write the value of x to led2
    led1=0
    @ nop
    led2=0
    goto loopy
    holdmem:
    x = led1  ; read the state of the porta.0 and place it in x
    'x = lata.0  ;or  read the state of the lata.0 and place it in x
    goto loopy
    Oct 2010
    ANSELA = 0
        DEFINE OSC 64
        OSCCON = $70
        OSCTUNE.6 = 1
        TRISA = %11111100
    loopy:
    led1=0
    @ nop
    led2=0
    goto loopy
    holdmem:
    goto loopy
    yes i think this is what i wanted to do. But when we use the following command:
    arent we write to EEPROM? Or this is temprorarly held in memory?
    your lack of understanding exceeds my wildest expectation ,i wasn't prepared for a beginner.
    if you like pm with me with your email and i will send a pic tutorial book i have as a pdf . its too big to post on forum
    until you comprehend the basic concepts of memory types and uses , binary numbers , basic boolean algebra , logic
    operators , i/o concepts ..... its just too hard
    Oct 2010
    thanks Richard will do.
    Oct 2010
    The program for the lockcode, at the moment works fine. As mentioned in my first post im not a programmer, i had to find a way to make it work.
    So the best suitable solution for me is to light up some LEDs and then read the status of the ports for confirmation.
    That's why i made those pins as output and then read the status to confirm if they are 0 or 1.
  1. 4 Wire resistive touch screen, Need help
    Last Post: - 16th February 2012, 18:28
  2. combination lock
    By korayfethi in forum Schematics
    Last Post: - 23rd May 2007, 21:02
  3. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
  4. touch screen
    By micro in forum General
    Last Post: - 13th January 2006, 04:39
  5. Touch Screen Wish List!!!
    By Amity in forum PBP Wish List
    Last Post: - 15th September 2005, 15:40
