Digital touch Screen Combination lock
Results 1 to 40 of 42
    Oct 2010
    Default Re: Digital touch Screen Combination lock
    im trying to understand what is going on with the help of the schematic , in lesson 1.
    Please give me some time.
    I just need to clarify something.
    when you write to all LATA register "0", is that just a number or is a bit? For example if we write
    LATA = 5
    Is that a number or is translated to a binary 00000101.
    So this writting to lat register
    LATA = 5
    represents the
    LATA = %00000101
    5 dec = 5 hex = bin 101 , numbers are just numbers
    all digital computers to date are binary devices and that's all they can cope with
    programs like pbp C mpasm ...... allow humans to specify numbers in any form we are comfortable with
    generally we have conventions to remove number base confusion
    eg 5 = $5 = 0x05 =%00000101 = 0b00000101= %101 =$05 = %000000000000000101 . the chip only ever sees the binary version
    Oct 2010
    What i mean is if that numbers corresponds to 8 LATx for example for portA
    LATA = 5
    is that number correspond to binary 8 bit LATA.x , so that number 5 will write only to %00000101 which is the LATA.0 and LATA.2
    Can we write a number then to only one LATA.x
    for example can we write
    LATA.0 = 5
    What that number will represent for the LATA.0
    based on the schematic logic gates receive only 0s or 1s. So LATA.x could only get 0s or 1s. Is that right?
    LATA = 5
    replaces the entire contents of lata latch with 5
    LATA.0 = 5
    is a syntax error a bit can only be 0 or 1
    lata.0 is bit 0 of the lata latch
    lesson 4 bit manipulation need 8 leds attached to porta:0-7
    These four routines [below] march a single lit led across the eight pins of porta from a0 to a7 when inserted in the shell provided.
    try each, which is the best do you think
    one of them could have "issues" @ 64mhz. which one? and why?
    can you reverse the direction of the march for each one ?
    can you light up the leds and march a single unlit led across the eight pins of porta from a0 to a7 ?
    i.
    PORTA.0=1
    WHILE PORTA
    PAUSE 200
    PORTA=PORTA<<1
    WEND
    ii.
    PORTA.0=1
    WHILE PORTA
    PAUSE 200
    PORTA=PORTA*2
    WEND
    iii.
    PORTA.0=1
    PAUSE 200
    PORTA.0=0
    PORTA.1=1
    PAUSE 200
    PORTA.1=0
    PORTA.2=1
    PAUSE 200
    PORTA.2=0
    PORTA.3=1
    PAUSE 200
    PORTA.3=0
    PORTA.4=1
    PAUSE 200
    PORTA.4=0
    PORTA.5=1
    PAUSE 200
    PORTA.5=0
    PORTA.6=1
    PAUSE 200
    PORTA.6=0
    PORTA.7=1
    PAUSE 200
    PORTA.7=0
    iv.
    PORTA=1
    PAUSE 200
    PORTA=2
    PAUSE 200
    PORTA=4
    PAUSE 200
    PORTA=8
    PAUSE 200
    PORTA=16
    PAUSE 200
    PORTA=32
    PAUSE 200
    PORTA=64
    PAUSE 200
    PORTA=128
    PAUSE 200
    PORTA=0
    #CONFIG  CONFIG  FOSC=INTIO67, PLLCFG=OFF, PRICLKEN=OFF, FCMEN=OFF, IESO=OFF
      CONFIG  PWRTEN=OFF, BOREN=SBORDIS, BORV=190, WDTEN=ON, WDTPS=32768
      CONFIG  CCP2MX=PORTC1, PBADEN=OFF, CCP3MX=PORTB5, HFOFST=ON, T3CMX=PORTC0
      CONFIG  P2BMX=PORTB5, MCLRE=EXTMCLR, STVREN=ON, LVP=OFF, XINST=OFF, DEBUG=OFF
      CONFIG  CP0=OFF, CP1=OFF, CP2=OFF, CP3=OFF, CPB=OFF, CPD=OFF, WRT0=OFF
      CONFIG  WRT1=OFF, WRT2=OFF, WRT3=OFF, WRTC=OFF, WRTB=OFF, WRTD=OFF, EBTR0=OFF
      CONFIG  EBTR1=OFF, EBTR2=OFF, EBTR3=OFF, EBTRB=OFF
    define  OSC 64
    OSCCON    = $70   ; 64Mhz
    OSCTUNE.6 =   1     ; Enable 4x PLL
    TRISA  = NOT 17
    ansela = ~ $FF
    LOOPY:
      ;insert code here
        PAUSE 3000
    GOTO LOOPY
    Oct 2010
    im still in lesson 1.
    i need to completely understand it with the use of the port schmeatic.
    Angry Re: Digital touch Screen Combination lock
    make lesson 1 loop like this and try with and without the nop
    loopy:
    lata=2
    pause 10
    porta.1 = 0
    ;@ nop
    porta.0 = 1
    goto loopy
    the secret is that leds when forward biased charge up , when you set them low the charge can hold the pin high long enough
    to trigger a rmw event on a fast chip. the nop allows enough time for the charge to dissipate {62 nano seconds}
  1. 4 Wire resistive touch screen, Need help
    Last Post: - 16th February 2012, 18:28
  2. combination lock
    By korayfethi in forum Schematics
    Last Post: - 23rd May 2007, 21:02
  3. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
  4. touch screen
    By micro in forum General
    Last Post: - 13th January 2006, 04:39
  5. Touch Screen Wish List!!!
    By Amity in forum PBP Wish List
    Last Post: - 15th September 2005, 15:40
