Digital touch Screen Combination lock
Results 1 to 40 of 42
    Default Re: Digital touch Screen Combination lock
    excuse me starting from lesson 2.
    First of all as from the configuration, all PORTA is digital with bit 7-2 as input and bit 1-0 to output.
    all PORTA is not digital its all analogue
    now you have given a number to lata = 3. Even if you change this number nothing happen so far.
    the result is fixed , changing the input conditions will never change the result . why ?
    LED 2 is opposite state from porta.1
    no its not its always set. why ?
    and LED 1 the same state as porta.1
    no its not its never set. why ?
    Oct 2010
    My bad, didint notice
    ;ANSELA = 0
    Now things are more confused.
    Really dont know. It might have to do with the analogue settings on the porta. I made all port digital and response to value changed. But really cant understand the reason.
    ports configured as analogue by default are read as low?
    nearly , pins configured as analogue always read as low
    Oct 2010
    these are my notes. I think i will try to understand why these happens.
    What i cannot understand is the writting to the portx or to latx.
    For example if we give alias:
    LED1 var LATX
    are we correspond the name to the LATX (not really writting to the LATX)
    So the same applies for the PORTX
    LED1 var PORTX
    The problem comes as i understand when we really write to the LATx or PORTx. Values are different.
    I need to do some exercises more on this.
    Oct 2010
    On the diagram above the Flip flop....is it an edge triggered D flip flop?
    If so i will focus on the schematic and i will try to understand what is going on in there.
    makes no difference
    when you write to lata you write directly to the porta output latches, only the pins declared as outputs are connected to the pins via the trisa "switch".
    when you write to porta you write directly to the porta output latches, only the pins declared as outputs are connected to the pins via the trisa "switch".
    when you read porta you read the digital logic level of all the porta pins , analog pins always read low
    when you read lata you read the porta output latches value not the digital logic level of all the porta pins
    when you write to a lata.pin you read the porta output latch value into the alu then,
    logically AND it with that pins bit value as 0 to CLEAR the pin
    or
    logically OR it with that pins bit value as 1 to SET the pin
    then write the result back to the porta output latches
    when you write to a porta.pin you read the porta pins value into the alu then,
    or
    if you did lesson one you would have noticed that port pins are subject to real world load conditions and that reading the pin value is not always what you wrote to it
    you need to allow for pin loading
    lesson two shows you can set and clear an analog pin made output but you can never read an analog pin properly
    lesson three shows you can read and write to output latches but they may not represent the pin values of that port they are always what you last wrote to the latch
    the diagram is for 1 pin
    Last edited by richard; - 18th August 2020 at 12:11. Reason: edited to English not gibberish
    Oct 2010
    im trying to understand what is going on with the help of the schematic , in lesson 1.
    Please give me some time.
    I just need to clarify something.
    when you write to all LATA register "0", is that just a number or is a bit? For example if we write
    LATA = 5
    Is that a number or is translated to a binary 00000101.
    So this writting to lat register
    LATA = 5
    represents the
    LATA = %00000101
    5 dec = 5 hex = bin 101 , numbers are just numbers
    all digital computers to date are binary devices and that's all they can cope with
    programs like pbp C mpasm ...... allow humans to specify numbers in any form we are comfortable with
    generally we have conventions to remove number base confusion
    eg 5 = $5 = 0x05 =%00000101 = 0b00000101= %101 =$05 = %000000000000000101 . the chip only ever sees the binary version
  1. 4 Wire resistive touch screen, Need help
    Last Post: - 16th February 2012, 18:28
  2. combination lock
    By korayfethi in forum Schematics
    Last Post: - 23rd May 2007, 21:02
  3. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
  4. touch screen
    By micro in forum General
    Last Post: - 13th January 2006, 04:39
  5. Touch Screen Wish List!!!
    By Amity in forum PBP Wish List
    Last Post: - 15th September 2005, 15:40
