Serial Sharing
Results 1 to 6 of 6
Thread: Serial Sharing
    Dec 2010
    Melbourne Australia
    Default Serial Sharing
    I have a system with 2 PIC processors and 1 RF module with a serial interface. Question is: can I connect both PICs to the input of the RF module to broadcast from both (not at the same time obviously) using a software command like Serout2?
    When dedicating a pin to be serial output, can you initialise the pin to be an input and let the Serout2 command to automatically switch the pin to an output when called? I ask that because the manual says "DataPin is automatically made an output"? Does that mean the pin is automatically reverted back to whatever I/O state it was set to after the packet it sent?
    Default Re: Serial Sharing
    a bit further down in the mode description is says
    Bit 15 selects whether the data pin is always driven (bit 15 = 0), or is open in one of the states (bit 15 = 1). The open mode can be used to chain several devices together on the same serial bus.
    Dec 2010
    Melbourne Australia
    Legend! Thanks again Richard!
    Dec 2010
    Melbourne Australia
    1 more quicky: so, if you chain 2 or more utilising the "open" state - I'm assuming that the open state is keeping them in high impedance mode when not transmitting - do you need a weak pullup or whatever on the line?
    Depends on the driver. But does no harm to have a high-ish value, say of 10K just to fix a space condition on the serial bus.
    Dec 2010
    Melbourne Australia
    Thanks Ioannis.
  1. Sharing my enthusiasm too!
    By ardhuru in forum WiFi
    Last Post: - 26th May 2016, 23:27
  2. Sharing Crystal with 2 IC's
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 10th January 2013, 13:33
  3. Variable sharing. Not sure how to describe this.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 14th April 2011, 15:29
  4. Sharing Serial connection
    By DynamoBen in forum Serial
    Last Post: - 9th March 2006, 18:07
  5. Sharing a USART
    By Ron Marcus in forum Serial
    Last Post: - 7th September 2005, 14:48
