Unable to execute MPASMX
Results 1 to 20 of 20
    Default Re: Unable to execute MPASMX
    Yikes! From the 5.40 relese notes:
    · MPLAB X IDE now a 64-bit application only. This version cannot be run on 32-bit operating systems; 64-bit operating systems are required.
    · MPASM no longer included in install. MPASM toolchain is 32-bit and is no longer supported. Therefore, you will see a message on opening the IDE that there is no toolchain installed.
    This does not sound too promising for the future of our beloved compiler...or does it? Perhaps this will allow (or even push) MeLabs to make the needed changes (though, as much I hate to say it, I personally doubt it).
    tumbleweed says that the new assembler isn't compatible with MPASM, I'd like some more details on that, like have they completely changed it so it will no longer be able to assemble a target executable from the .lst file PBP produces?
    If the .lst file is different now (in the MPLABX IDE environment) for sure there would be no compatibility...
    But if the change in the name is the problem, maybe the pic-as.exe can be renamed and the MCS can find it and use it.
    I do not have time to download and test this right now. If anyone?
    Henrik, if the compiler does not support the new PIC's there is no point in updating to new MPLABX assembler, right?
  1. Mpasmx
    By Cyberdove in forum mel PIC BASIC Pro
    Last Post: - 25th October 2017, 00:18
  2. Unable to execute mpasmwin
    By oldmainframer in forum General
    Last Post: - 18th December 2016, 00:01
  3. How long does this take to execute
    By dsicon in forum PBP3
    Last Post: - 20th August 2016, 11:26
  4. Replies: 3
    Last Post: - 20th December 2009, 13:57
  5. Replies: 1
    Last Post: - 27th August 2009, 03:42
