How to prevent variable going below zero?
Results 1 to 28 of 28
    Default Re: How to prevent variable going below zero?
    So this "wrapping" is compiler related issue and can't be fixed, as I understand?
    Technically, I solved this problem by making I change between 5 and 260, and outputting HPWM 2,I-5,10000.
    If you mean a compiler problem, no. It is not.
    If you mean how binary arithmetic works, yes. That is how you count, add or subtract in binary having byte, word or other size variables. In any case that is how you do it in decimal also but do not give it much attention.
    The "fix" is in the answers given already to you. SELECT CASE, test before updating for valid result, etc...
  1. Assigning a string variable to another string variable
    Last Post: - 2nd June 2013, 18:55
  2. Variable within Variable
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 15:44
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 14:13
  4. One variable made up of another variable
    Last Post: - 1st September 2007, 01:18
  5. 2 variable
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 24th May 2004, 22:59
