How to prevent variable going below zero?
Results 1 to 28 of 28
    Default Re: How to prevent variable going below zero?
    You are absolutely right! I do not trust that this may be the case for any PIC though.
    its a quick easy test to check, it works on all chips that i tried just make sure the compiler dosn't compress the subtract into a decrement
    i var can be byte or word
    j=8
    i=6
    while j
    status=1
     i=i-2  ;subtractant cannot be 1
    s=status
    debug 13,10,"status ",bin8 s ,"  i ",    dec i
    j=j-1
    wend
    Well, thanks for checking out. Wow!
  1. Assigning a string variable to another string variable
    Last Post: - 2nd June 2013, 18:55
  2. Variable within Variable
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 15:44
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 14:13
  4. One variable made up of another variable
    Last Post: - 1st September 2007, 01:18
  5. 2 variable
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 24th May 2004, 22:59
