How to prevent variable going below zero?
Results 1 to 28 of 28
    Default Re: How to prevent variable going below zero?
    Will this work for you?
    iflag var bit
    let iflag =0
    reader:
    adcin 0,Z
    IF Z>100 AND Z<130 THEN I=I+5
    IF Z<100 and iflag = 0 THEN I=I-5 'only if iflag = 0 it's OK to substract
    if i>255 then i=255
    if i<5 then i=0
    if i = 0 then let iflag = 1 'if i hits 0 put up a flag
    if i >= 5 then let iflag = 0 'once i hits 5 or more, reset the flag
    HPWM 2,I,10000
    XY=I
    gosub decoder
    goto reader
    Try this:
    if Z.15 = 1 then
    Z = 0
  1. Assigning a string variable to another string variable
    Last Post: - 2nd June 2013, 18:55
  2. Variable within Variable
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 15:44
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 14:13
  4. One variable made up of another variable
    Last Post: - 1st September 2007, 01:18
  5. 2 variable
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 24th May 2004, 22:59
