How to prevent variable going below zero?
Results 1 to 28 of 28
    Default Re: How to prevent variable going below zero?
    And since here is PBP forum, not general representation forum, I'm asking how to deal with this in PBP
    Will this work for you?
    iflag var bit
    let iflag =0
    reader:
    adcin 0,Z
    IF Z>100 AND Z<130 THEN I=I+5
    IF Z<100 and iflag = 0 THEN I=I-5 'only if iflag = 0 it's OK to substract
    if i>255 then i=255
    if i<5 then i=0
    if i = 0 then let iflag = 1 'if i hits 0 put up a flag
    if i >= 5 then let iflag = 0 'once i hits 5 or more, reset the flag
    HPWM 2,I,10000
    XY=I
    gosub decoder
    goto reader
    Try this:
    if Z.15 = 1 then
    Z = 0
    Aug 2011
    In your original code, change
    IF Z<100 THEN I=I-5
    to this
    IF Z<100 AND I>=5 THEN I=I-5
  1. Assigning a string variable to another string variable
    Last Post: - 2nd June 2013, 18:55
  2. Variable within Variable
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 15:44
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 14:13
  4. One variable made up of another variable
    Last Post: - 1st September 2007, 01:18
  5. 2 variable
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 24th May 2004, 22:59
