"Variable already an alias" - is there a way to avoid this?
Results 1 to 33 of 33
    Default Re: "Variable already an alias" - is there a way to avoid this?
    Here version with HPWM controlled color setting mode
    And by adding properly synced multiplexing, even nicer effects can be obtained. Too bad they do not make RGB 7 segment displays in manageable size or price....
    As you can see, greens are less bright than reds, this is due fact, that there are two leds in series for each color and each segment, so driving them from 5V makes green look less brighter. To achieve same level of brightness of green as red has, it needs about 5.8V, which is way too high and most likely will burn my MCU, so I'm avoiding that at all costs.
    Oct 2010
    Attachment 8887
    very nice work. thanks for sharing. I'm not going to use your code but definately it will help me understand some things.
    I've added external drivers to circuitry, so voltage now not an issue, so brightness also can be increased
    Bringing up an old thread...
    I have CD4514 connected with it's ABCD inputs to upper 4 bits of PORT.D (PORTD4-7)
    I have variable that changes values between 0 and 16. Name is A
    How Can I directly write this variable to these upper bits?
    PORTD.0[4+A]=A seems not to be working...
    Sep 2009
    Try
    PORTD.4=A.0
    PORTD.5=A.1
    PORTD.6=A.2
    PORTD.7=A.3
    Another way
    PORTD=A>>4
    Thanks, that works!
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 03:01
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  5. Replies: 1
    Last Post: - 16th February 2005, 21:05
