"Variable already an alias" - is there a way to avoid this?
Results 1 to 33 of 33
    Default Re: "Variable already an alias" - is there a way to avoid this?
    FOR A=1 to 32
    PORTA.0[A]=1
    NEXT
    Will make all ports of PORTA/PORTB/PORTC/PORTD high in sequence, right? (All TRIS and other yada-yada are already set).
    Since you start your offset value (the FOR loop) at 1 it the first bit to be set will be "one away" from PortA.0, in other words PortA.1 and then contiune 32 bits "up from there", so you will write to the first bit of the register comming after PortD - that can ruin your day.
    But, as Richard says, TRY IT for crying out loud :-) Investigate how it works, does it do what you expect, change something and see if you get the expected result and if not think about WHY.
    Well my circuit is already built, software written and it works fine, just it takes about 7.3k memory, so I'd like to slim it down. If anyone want to build a LED clock, with directly driven segments, using PIC16F887 and DS3231, here's the working code (it needs some cleanup, unused labels and variables should be removed, but it works just fine as it is). I also can upload gerber files of PCB. I'm planning to add some extra features to existing hardware, like user digit style selection (US/EU/JP) and temperature measurement via DS18B20, but all this later.
    cfg1 = _INTRC_OSC_NOCLKOUT    ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg1&= _WDT_ON                ; WDT enabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOR_OFF               ; BOR disabled
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
    cfg1&= _LVP_OFF               ; RB3 pin has digital I/O, HV on MCLR must be used for programming
    cfg1&= _DEBUG_OFF             ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
      __CONFIG _CONFIG1, cfg1
    cfg2 = _BOR40V                ; Brown-out Reset set to 4.0V
    cfg2&= _WRT_OFF               ; Write protection off
      __CONFIG _CONFIG2, cfg2
    'nixie led clock electronics direct drive
    'include "modedefs.bas"
    OSCCON=%01110101  'SET INTOSC TO 8MHZ
    ANSEL=%00000000
    ANSELH=%00000000 'disable ADC
    TRISC=%00000000 'set PORTC as output all
    TRISD=%00000000 'set PORTD as output all
    TRISB=%00000000 'set PORTB as output all
    TRISA=%00000001 'set PORTA 0 as input, others as output
    TRISE=%00000000
    'OPTION_REG=%100000000 'disable portb pullups
    DEFINE OSC 8   'OSC SPEED
    'turn off all digits
    PORTA=0: PORTB=0: PORTC=0: PORTD=0 : PORTE=0
    'PIN CONFIG
    FEXI VAR PORTA.0
    'BUZZER
    low portA
    low portb
    low portc
    low portd
    low porte
    '1 digit
    A1 VAR PORTD.3: B1 VAR PORTC.4: C1 VAR PORTC.1: D1 VAR PORTC.2: E1 VAR PORTD.0
    F1 VAR PORTD.2: G1 VAR PORTC.5:
    '2
    A2 VAR PORTD.4: B2 VAR PORTD.5: C2 VAR PORTA.7: D2 VAR PORTA.6: E2 VAR PORTC.0
    G2 VAR PORTC.6: F2 VAR PORTC.7
    '3
    A3 VAR PORTB.2: B3 VAR PORTB.5: C3 VAR PORTA.5: D3 VAR PORTE.0: E3 VAR PORTE.1
    F3 VAR PORTB.1: G3 VAR PORTB.0:
    '4
    A4 VAR PORTD.7: B4 VAR PORTD.6: C4 VAR PORTA.1: D4 VAR PORTA.2: E4 VAR PORTA.3
    F4 VAR PORTB.3: G4 var PORTB.4
    DOT VAR PORTE.2
    'BUT VAR PORTA.0
    BUZ var PORTB.7
    SDA VAR PORTD.1
    SCL VAR PORTC.3
    'PORTA.4	UNUSED
    'dot
    'my time variables
    RTCYear  Var Byte: RTCMonth Var Byte: RTCDate  Var Byte: RTCDay   Var Byte: RTCHour  Var Byte
    RTCMin   Var Byte: RTCSec   Var Byte: RTCCtrl  Var Byte
    saatebi var word   'hours
    cutebi var word    'minutes
    clebi var word     'years
    tve var word       'months
    dge var word        'days
    DRO var byte       'temp time holder
    cvladi var word
    cvlileba var byte 'detect time change variable
    dlycnt var word 'delay counter for keyboard debouncing.
    menuitem var byte 'selected menu item number
    ticker var word 'counter for loop waiting
    alhr var word 'alarm hours
    almin var word 'alarm minutes
    alwk var byte 'alarm on/off weekends on/off
    HR24 var byte 'HR24 mode
    tcr var byte ' time corrector variable
    rmd var byte ' refresh mode selection
    ROLL VAR BYTE 'ROLL ENABLE/DISABLE
    trigfix var byte 'corrector reset variable
    X VAR WORD ' TEMP VARIABLE refresh time
    Y var word 'dot display delay
    Z var word 'temp variable 3
    Z1 var word 'temp 4
    Z2 var word 'temp 5
    Z3 var word 'temp 6
    T1 VAR WORD 'VARIABLES FOR TIME DIGITS
    T2 VAR WORD 'from left to right
    T3 VAR WORD
    T4 VAR WORD
    '______________initial variable values
    trigfix=1
    cvladi=0
    ticker=0
    dlycnt=0
    menuitem=0
    TCR=30
    X=1
    y=1
    Z=1    'high dot
    FOR Y=1 TO 3
    GOSUB CLEANER
    X=350
    LOW E4: LOW D4: LOW C4: LOW B4: LOW A4 'A AT 4
    PAUSE X
    GOSUB CLAR4
    LOW E3: LOW D3: LOW C3: LOW B3: LOW A3 'A AT 3
    LOW A4: LOW B4: LOW F4: LOW E4: LOW D4 'L AT 4
    PAUSE X
    GOSUB CLAR4: GOSUB CLAR3
    LOW A4: LOW B4: LOW C4: LOW D4 'E AT 4
    LOW A3: LOW B3: LOW F3: LOW E3: LOW D3 'L AT 3
    LOW E2: LOW D2: LOW C2: LOW B2: LOW A2 'A AT 2
    PAUSE X
    GOSUB CLAR4: GOSUB CLAR3: GOSUB CLAR2
    LOW E1: LOW D1: LOW C1: LOW B1: LOW A1 'A AT 1
    LOW A2: LOW B2: LOW F2: LOW E2: LOW D2 'L AT 2
    LOW A3: LOW B3: LOW C3: LOW D3 'E AT 3
    LOW B4: LOW G4: LOW C4: LOW D4 'Q AT 4
    PAUSE X
    GOSUB CLEANER
    LOW A1: LOW B1: LOW F1: LOW E1: LOW D1 'L AT 1
    LOW A2: LOW B2: LOW C2: LOW D2 'E AT 2
    LOW B3: LOW G3: LOW C3: LOW D3 'Q AT 3
    LOW F4: LOW E4: LOW D4: LOW C4 'S AT 4
    PAUSE X
    GOSUB CLEANER
    LOW A1: LOW B1: LOW C1: LOW D1 'E AT 1
    LOW B2: LOW G2: LOW C2: LOW D2 'Q AT 2
    LOW F3: LOW E3: LOW D3: LOW C3 'S AT 3
    LOW E4: LOW F4: LOW A4: LOW B4: LOW C4 'I AT 4
    PAUSE X
    GOSUB CLEANER
    LOW B1: LOW G1: LOW C1: LOW D1 'Q AT 1
    LOW F2: LOW E2: LOW D2: LOW C2 'S AT 2
    LOW E3: LOW F3: LOW A3: LOW B3: LOW C3 'I AT 3
    GOSUB CLAR4
    PAUSE X
    GOSUB CLEANER
    LOW F1: LOW E1: LOW D1: LOW C1 'S AT 1
    LOW E2: LOW F2: LOW A2: LOW B2: LOW C2 'I AT 2
    GOSUB CLAR3
    PAUSE X
    GOSUB CLEANER
    LOW E1: LOW F1: LOW A1: LOW B1: LOW C1 'I AT 1
    GOSUB CLAR2
    PAUSE X
    GOSUB CLEANER
    PAUSE X
    NEXT
    PAUSE 1000
    GOSUB EREAD ' read eeprom values
    gosub ZEROPLAY ' show zeros
    for Z=1 to 4000
    pause 1
    if fexi=0 then gosub longbibi: goto setuploop
    next
    goto demoscene
    setuploop:  'configuration
    if fexi=0 then
    dlycnt=dlycnt+1 'increase debounce variable while button is pressed
    ticker=ticker+1
    pause 1
    if ticker>1500 and  fexi=0 then gasvla 'if long pressed, then exit and (or) go to selector item
    if fexi=1 and dlycnt>100 then  'if short pressed, then do the rap
    ticker=0
    dlycnt=0
    pause 1
    menuitem=menuitem+1  'this is incremental variable, substitute another next time you need it
    if menuitem>14 then menuitem=0
    t1=menuitem dig 1: t2=menuitem dig 0: gosub display ' display current item
    gosub bibi
    goto setuploop
    gasvla:
    ticker=0:dlycnt=0 'RESET COUNTER VARIABLES
    gosub bibi  'beep
    'read RTC values into system variables
    gosub gettime     'READ TIMES
    gosub timedecode  'CONVERT TO DEC
    GOSUB EREAD  'READ EEPROM
    IF alhr=255 THEN alhr=0 'RESET alarm hours VARIABLE FOR FIRST RUN
    IF almin=255 THEN almin=0 'RESET alarm hours VARIABLE FOR FIRST RUN
    IF HR24=255 THEN HR24=0 'RESET HR24 VARIABLE FOR FIRST RUN
    IF alwk=255 THEN alwk=0 'RESET week alarm VARIABLE FOR FIRST RUN
    if tcr=255 then tcr=30 'reset time corrector to default
    if rmd=255 then rmd=0 'set refresh value to default
    IF ROLL=255 THEN ROLL=0 'SET ROLL MODE INITIAL
    gosub yeardecode
    clebi=T3*10+T4
    gosub monthdaydecode
    tve=T1*10+T2 ' get month
    dge=T3*10+T4 'get day
    if menuitem=0 then  DEMOSCENE
    if menuitem=1 then  YSET 'year set
    IF MENUITEM=2 THEN  MSET 'month set
    IF MENUITEM=3 THEN  DSET 'date set
    IF MENUITEM=4 THEN  HSET 'hour set
    IF MENUITEM=5 THEN  TSET 'minute set
    IF MENUITEM=6 THEN  HRMD '12/24 hour set
    IF MENUITEM=7 THEN  AHRS 'alarm hours
    IF MENUITEM=8 THEN  AMIN 'alarm minutes
    IF MENUITEM=9 THEN  ASET 'alarm/snooze enabled/disabled
    'if menuitem=10 then RSET 'roll enable/disable
    if menuitem=10 then RMOD 'refresh mode selection
    if menuitem=11 then TCOR 'enter time corrector value
    if menuitem=12 then FACHO 'go to segment looper
    if menuitem=13 then DAYSET 'set day of the week
    if menuitem=14 then DBGR 'debug mode
    pause 200
    goto setuploop
    DEMOSCENE: 'main code loop
    gosub gettime
    gosub timedecode
    'if Z3=30 then 'enable dot 30 seconds
    'high dot
    'pause 1
    'low dot
    'endif
    if HR24=1 then gosub corrector 'adjust time to 24hr format
    if cvlileba=1 then
    'high dot
    trigfix=1 'reset trigger alarm
    low buz 'silence the alarm
    pause 1
    'low dot
    gosub segtest  'if time changed, then let's animate display
    't3= z dig 1
    't4=z dig 0
    gosub display
    FOR Y=1 TO 500
    PAUSE 1
    HIGH dot   'blink the separator dots
    IF FEXI=0 THEN GOSUB TDM
    NEXT Y
    FOR Y=1 TO 500
    PAUSE 1
    low dot   'blink the separator dots
    NEXT Y
    ' alarm subroutine
    if alwk=1 and saatebi=alhr and cutebi=almin and trigfix=1 then   'alarm all weekdays
    high buz
    if alwk=2 and saatebi=alhr and cutebi=almin and trigfix=1 and RTCDAY<6 then   'alarm on workdays
    'T1=0:T2=0
    'T3=ALHR DIG 1: T4=ALHR DIG 0: GOSUB DISPLAY
    'T1=0:T4=RTCDAY
    'GOSUB DISPLAY
    'PAUSE 2000
    high buz
    GOTO DEMOSCENE
    TDM: 'display year, month, date
    trigfix=0
    low buz 'turn of buzzer if enabled
    GOSUB YEARDECODE
    gosub meko
    GOSUB DISPLAY
    'LOW DOT
    PAUSE 2000  'adjust these "2000" values for desired delay between displayed info change
    GOSUB MONTHDAYDECODE
    gosub meko
    GOSUB DISPLAY
    'HIGH DOT
    PAUSE 2000
    'LOW DOT
    if alwk<>0 then 'if alarm is enabled, show it's value
    gosub meko
    t1=alhr dig 1: t2=alhr dig 0: t3=almin dig 1: t4=almin dig 0: gosub display: pause 2000 'display alarm
    gosub meko
    ' Subroutine to write time to RTC
    settime:
    'rtcsec=0 ' this is necessary to make clock tick
       I2CWrite SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    ' Subroutine to read time from RTC
    gettime:
       I2CRead SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
       if DRO<>rtcmin then  'check for time changes, so display only is refreshed when time is changed
       cvlileba=1
       cvlileba=0
     DRO=rtcmin
    timedecode:       'decode time from RTC into values suitable for nixie digit illumination
       t1=rtchour >> 4
       t2=rtchour // 16
       t3=rtcMin >> 4
       T4=rtcMin // 16
       Z1=RTCSEC >> 4
       Z2=RTCseC // 16
    saatebi=t1*10+t2 'read hours
    cutebi=T3*10+T4 ' read minutes
    z3=Z1*10+Z2 'READ SECONDS
    IF SAATEBI=23 AND CUTEBI=58 AND Z3=30 and tcr<>30 THEN
    GOSUB CHIPFIX 'RESET MIDNIGHT CHIP
    yeardecode:
       t1=2
       t2=0
       T3=rtcyear >> 4
       T4=rtcyear // 16
    monthdaydecode:
       t1=rtcmonth >> 4
       t2=rtcmonth // 16
       T3=rtcdate >> 4
       T4=rtcdate // 16
    SEGTEST:  'refresh all segments with cool animation
    IF RMD=0 THEN KEKO
    IF RMD=1 THEN ZEKO
    IF RMD=2 THEN MEKO
    KEKO: 'ANOTHER ROLL MODE
    zeko:
    meko:
    DISPLAY: 'DECODE VALUES AND DISPLAY THEM
    x=t1: Y=1: GOSUB DECODER
    x=t2: Y=2: GOSUB DECODER
    x=t3: Y=3: GOSUB DECODER
    X=t4: Y=4: GOSUB DECODER
    pause 10
          'ended
    :FACHO  'test all segments
    corrector: 'adjust for 12 hour display
    IF T1=1 AND T2=3 THEN T2=1:T1=0
    IF T1=1 AND T2=4 THEN T2=2:T1=0
    IF T1=1 AND T2=5 THEN T2=3:T1=0
    IF T1=1 AND T2=6 THEN T2=4:T1=0
    IF T1=1 AND T2=7 THEN T2=5:T1=0
    IF T1=1 AND T2=8 THEN T2=6:T1=0
    IF T1=1 AND T2=9 THEN T2=7:T1=0
    IF T1=2 AND T2=0 THEN T2=8:T1=0
    IF T1=2 AND T2=1 THEN T2=9:T1=0
    IF T1=2 AND T2=2 THEN T2=0:T1=1
    IF T1=2 AND T2=3 THEN T2=1:T1=1
    'EEPROM READ AND WRITE
    EREAD:
    READ 1, HR24 'READ 12/24 HOUR MODE VARIABLE
    READ 2, ALWK 'READ ALARM ENABLE/DISABLE AND WEEK
    READ 3, ALHR 'READ ALARM HOURS
    READ 4, ALMIN 'READ ALARM MINUTES
    read 5, HR24 'HR24 value
    read 6, tcr ' time corrector value
    read 7, rmd 'refresh mode
    READ 8, ROLL 'ROLL MODE
    EWRITE:
    WRITE 1, HR24 'READ 12/24 HOUR MODE VARIABLE
    WRITE 2, ALWK 'READ ALARM ENABLE/DISABLE AND WEEK
    WRITE 3, ALHR 'READ ALARM HOURS
    WRITE 4, ALMIN 'READ ALARM MINUTES
    write 5, HR24 'HR24 value
    write 6, tcr ' time corrector value
    write 7, rmd 'refresh mode
    WRITE 8, ROLL 'ROLL MODE
    BIBI:   'MAKE DA NOIZE
    high buz
    low buz
    LONGBIBI: 'exit confirmation with long beep and variables reset
    ticker=0: dlycnt=0: menuitem=0 'reset variables again
    high buz
    PAUSE 400
    low buz
    '_setup subroutines____________________________________________________________
    YSET:	'SET THE YEAR
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub LONGBIBI
    gosub ZEROPLAY 'reset display
    goto setuploop 'if long pressed, then exit and (or) go to selector item
    ticker=0
    dlycnt=0
    clebi=clebi+1
    if clebi>59 then clebi=20
    	rtcyear=clebi DIG 1
    	rtcyear=rtcyear<<4
    	rtcyear=rtcyear+clebi DIG 0
    gosub settime
    'lcdout $fe,$c0, " Year: ", #clebi,"           "  'debug just for case
    T1=0:t2=1:t3=clebi dig 1: t4=clebi dig 0: gosub display
    pause 1
    gosub bibi
    goto yset
    MSET:	'SET THE MONTH
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    tve=tve+1
    if tve>12 then tve=1
    	rtcmonth=tve DIG 1
    	rtcmonth=rtcmonth<<4
    	rtcmonth=rtcmonth+tve DIG 0
    gosub settime
    'lcdout $fe,$c0, " Month: ", #tve,"           "  'debug just for case
    T1=0:t2=2:t3=tve dig 1: t4=tve dig 0: gosub display
    pause 1
    gosub bibi
    goto MSET
    DSET:	'SET THE DATE
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub ZEROPLAY
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    dge=dge+1
    if dge>31 then dge=1
    	rtcdate=dge DIG 1
    	rtcdate=rtcdate<<4
    	rtcdate=rtcdate+dge DIG 0
    gosub settime
    'lcdout $fe,$c0, " Day: ", #dge,"           "  'debug just for case
    T1=0:t2=3:t3=dge dig 1: t4=dge dig 0: gosub display
    pause 1
    gosub bibi
    goto DSET
    HSET:	'SET THE HOURs
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    saatebi=saatebi+1
    if saatebi>23 then saatebi=0
    	rtchour=saatebi DIG 1
    	rtchour=rtchour<<4
    	rtchour=rtchour+saatebi DIG 0
    gosub settime
    T1=0:t2=4:t3=saatebi dig 1: t4=saatebi dig 0: gosub display
    pause 1
    gosub bibi
    goto HSET
    TSET:	'SET THE minutes
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    cutebi=cutebi+1
    if cutebi>59 then cutebi=0
    	rtcmin=cutebi DIG 1
    	rtcmin=rtcmin<<4
    	rtcmin=rtcmin+cutebi DIG 0
    gosub settime
    T1=0:t2=5:t3=cutebi dig 1: t4=cutebi dig 0: gosub display
    pause 1
    gosub bibi
    GOTO TSET
    AHRS:	'SET THE ALARM HOURS
    if fexi=0 then
    ticker=ticker+1
    pause 1
    GOSUB EWRITE 'WRITE VARIABLES TO EEPROM
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    alhr=alhr+1
    if alhr>23 then alhr=0
    T1=0:t2=7:t3=alhr dig 1: t4=alhr dig 0: gosub display
    pause 1
    gosub bibi
    goto AHRS
    AMIN:	'SET THE ALARM MINUTES
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    almin=almin+1
    if almin>59 then almin=0
    T1=0:t2=8:t3=almin dig 1: t4=almin dig 0: gosub display
    pause 1
    gosub bibi
    goto AMIN
    ASET:	 'ENABLE/DISABLE ALARM/SNOOZE 'SET ALARM ON WEEKENDS
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    alwk=alwk+1
    if alwk>2 then alwk=0
    T1=0:t2=9:t3=alwk dig 1: t4=alwk dig 0: gosub display
    pause 1
    gosub bibi
    goto ASET
    HRMD:	'HR24 MODE/12-24 HOURS
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    HR24=HR24+1
    if HR24>1 then HR24=0
    T1=0:t2=6:t3=0: t4=HR24 dig 0: gosub display
    pause 1
    gosub bibi
    GOTO HRMD
    RMOD:	'REFRESH MODE SELECTION
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    RMD=RMD+1
    if RMD>2 then RMD=0
    T1=1:t2=0:t3=0: t4=RMD dig 0: gosub display
    pause 1
    gosub bibi
    GOTO RMOD
    RSET:	'ROLL SET
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    ROLL=ROLL+1
    if ROLL>1 then ROLL=0
    T1=1:t2=0:t3=0: t4=ROLL dig 0: gosub display
    pause 1
    gosub bibi
    GOTO RSET
    TCOR:	'TIME CORRECTOR SET
    if fexi=0 then
    ticker=ticker+1
    pause 1
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    TCR=TCR+1
    if TCR>45 then TCR=15
    T1=1:t2=2:t3=TCR DIG 1: t4=TCR dig 0: gosub display
    pause 1
    gosub bibi
    GOTO TCOR
    ZEROPLAY: 'clear the display and set to 00s
    T1=0: t2=0: t3=0: t4=0
    gosub display
    CHIPFIX: 'SUBROUTINE FOR FIXING DS3231 ISSUES
    if tcr<>30 then
    rtcsec=z3 DIG 1
    rtcsec=rtcsec << 4    'convert time to RTC format
    rtcsec=rtcsec+z3 DIG 0
    GOSUB SETTIME
    'high buz
    'pause 1000
    'low buz
    DAYSET: 'set day of week
    if fexi=0 then
    ticker=ticker+1
    pause 1
    GOSUB gettime  'read time variables
    RTCDAY=X 'write to RTCDAY
    gosub settime 'write it
    gosub zeroplay
    gosub LONGBIBI
    ticker=0
    dlycnt=0
    RTCDay=RTCDay+1
    if RTCDay>7 then RTCDay=1
    T1=1:t2=3:t3=0: t4=RTCDAY: gosub display
    pause 1
    gosub bibi
    X=RTCDAY
    goto DAYSET
    DBGR: 'debug info display
    T1=0: T2=0: t3=0: T4=TRIGFIX
    GOSUB DISPLAY
    PAUSE 2000
    gosub gettime 'read time
    gosub yeardecode 'convert to decimal
    T1=0: t2=1
    gosub display   'year
    pause 2000
    GOSUB DISPLAY  'month/day
    pause 2000
    gosub timedecode 'time
    gosub display
    pause 2000
    t1=1: t2=1: t3=0:t4=rtcday  'day
    gosub display
    pause 2000
    t1=2: t2=2: t3=rtcsec dig 1:t4=rtcsec dig 0 'seconds
    gosub display
    pause 2000
    gosub eread
    T1=0:t2=0: t3=0: t4= hr24 'time format var
    gosub display
    pause 2000
    T1=0:t2=0: t3=0: t4= alwk 'alarm mode
    gosub display
    pause 2000
    T1=0:t2=0: t3=alhr dig 1: t4= alhr dig 0 'alarm hours
    gosub display
    pause 2000
    T1=0:t2=0: t3=almin dig 1: t4= almin dig 0 'alarm minutes
    gosub display
    pause 2000
    T1=0:t2=0: t3=tcr dig 1: t4= tcr dig 0 'corrector value
    gosub display
    pause 2000
    T1=0:t2=0: t3=rmd dig 1: t4= rmd dig 0 'refresh mode
    gosub display
    pause 2000
    T1=0:t2=0: t3=roll dig 1: t4= roll dig 0 'roll value
    gosub display
    pause 2000
    gosub longbibi
    goto setuploop
    DECODER:   'DECODER ROUTINE
    IF X=0 AND Y=1 THEN GOSUB N10 'displays specific digit for specific segment
    IF X=1 AND Y=1 THEN GOSUB N11
    IF X=2 AND Y=1 THEN GOSUB N12
    IF X=3 AND Y=1 THEN GOSUB N13
    IF X=4 AND Y=1 THEN GOSUB N14
    IF X=5 AND Y=1 THEN GOSUB N15
    IF X=6 AND Y=1 THEN GOSUB N16
    IF X=7 AND Y=1 THEN GOSUB N17
    IF X=8 AND Y=1 THEN GOSUB N18
    IF X=9 AND Y=1 THEN GOSUB N19
    IF X=0 AND Y=2 THEN GOSUB N20
    IF X=1 AND Y=2 THEN GOSUB N21
    IF X=2 AND Y=2 THEN GOSUB N22
    IF X=3 AND Y=2 THEN GOSUB N23
    IF X=4 AND Y=2 THEN GOSUB N24
    IF X=5 AND Y=2 THEN GOSUB N25
    IF X=6 AND Y=2 THEN GOSUB N26
    IF X=7 AND Y=2 THEN GOSUB N27
    IF X=8 AND Y=2 THEN GOSUB N28
    IF X=9 AND Y=2 THEN GOSUB N29
    IF X=0 AND Y=3 THEN GOSUB N30
    IF X=1 AND Y=3 THEN GOSUB N31
    IF X=2 AND Y=3 THEN GOSUB N32
    IF X=3 AND Y=3 THEN GOSUB N33
    IF X=4 AND Y=3 THEN GOSUB N34
    IF X=5 AND Y=3 THEN GOSUB N35
    IF X=6 AND Y=3 THEN GOSUB N36
    IF X=7 AND Y=3 THEN GOSUB N37
    IF X=8 AND Y=3 THEN GOSUB N38
    IF X=9 AND Y=3 THEN GOSUB N39
    IF X=0 AND Y=4 THEN GOSUB N40
    IF X=1 AND Y=4 THEN GOSUB N41
    IF X=2 AND Y=4 THEN GOSUB N42
    IF X=3 AND Y=4 THEN GOSUB N43
    IF X=4 AND Y=4 THEN GOSUB N44
    IF X=5 AND Y=4 THEN GOSUB N45
    IF X=6 AND Y=4 THEN GOSUB N46
    IF X=7 AND Y=4 THEN GOSUB N47
    IF X=8 AND Y=4 THEN GOSUB N48
    IF X=9 AND Y=4 THEN GOSUB N49
    N10: '0 at 1st digit
    GOSUB CLAR1
    LOW A1: LOW B1: LOW C1: LOW D1: LOW E1: LOW F1 '0
    N11: '1 AT 1ST DIGIT
    GOSUB CLAR1
    low b1: low c1 '1
    N12:
    GOSUB CLAR1
    low A1: low B1: low g1: low e1: low d1 '2
    N13:
    GOSUB CLAR1
    low A1: LOW B1: LOW C1: LOW D1: LOW G1 '3
    N14:
    GOSUB CLAR1
    LOW F1: LOW B1: LOW G1: LOW C1 '4
    N15:
    GOSUB CLAR1
    LOW A1: LOW F1: LOW G1: LOW C1: LOW D1 '5
    N16:
    GOSUB CLAR1
    LOW F1: LOW A1: LOW G1: LOW E1: LOW D1: LOW C1 'C6
    N17:
    GOSUB CLAR1
    low A1: low B1: low C1 '7
    N18:
    gosub CLAR1
    low A1: low B1: low C1: low f1: low e1: low g1: low d1 '8
    N19:
    gosub CLAR1
    low A1: low B1: low C1: low f1: low g1: low d1 '9
    CLAR1: 'clear 1ST DIGIT
    high A1: high B1: high C1: high d1: high e1: high f1: high g1
    N20: '0 at 1st digit
    GOSUB CLAR2
    LOW A2: LOW B2: LOW C2: LOW D2: LOW E2: LOW F2 '0
    N21: '1 AT 1ST DIGIT
    GOSUB CLAR2
    low b2: low c2 '1
    N22:
    GOSUB CLAR2
    low A2: low B2: low g2: low e2: low d2 '2
    N23:
    GOSUB CLAR2
    low A2: LOW B2: LOW C2: LOW D2: LOW G2 '3
    N24:
    GOSUB CLAR2
    LOW F2: LOW B2: LOW G2: LOW C2 '4
    N25:
    GOSUB CLAR2
    LOW A2: LOW F2: LOW G2: LOW C2: LOW D2 '5
    N26:
    GOSUB CLAR2
    LOW F2: LOW A2: LOW G2: LOW E2: LOW D2: LOW C2 'C6
    N27:
    GOSUB CLAR2
    low A2: low B2: low C2 '7
    N28:
    gosub CLAR2
    low A2: low B2: low C2: low f2: low e2: low g2: low d2 '8
    N29:
    gosub CLAR2
    low A2: low B2: low C2: low f2: low g2: low d2 '9
    CLAR2: 'clear 1ST DIGIT
    high A2: high B2: high C2: high d2: high e2: high f2: high g2
    N30: '0 at 1st digit
    GOSUB CLAR3
    LOW A3: LOW B3: LOW C3: LOW D3: LOW E3: LOW F3 '0
    N31: '1 AT 1ST DIGIT
    GOSUB CLAR3
    low b3: low c3 '1
    N32:
    GOSUB CLAR3
    low A3: low B3: low g3: low e3: low d3 '2
    N33:
    GOSUB CLAR3
    low A3: LOW B3: LOW C3: LOW D3: LOW G3 '3
    N34:
    GOSUB CLAR3
    LOW F3: LOW B3: LOW G3: LOW C3 '4
    N35:
    GOSUB CLAR3
    LOW A3: LOW F3: LOW G3: LOW C3: LOW D3 '5
    N36:
    GOSUB CLAR3
    LOW F3: LOW A3: LOW G3: LOW E3: LOW D3: LOW C3 'C6
    N37:
    GOSUB CLAR3
    low A3: low B3: low C3 '7
    N38:
    gosub CLAR3
    low A3: low B3: low C3: low f3: low e3: low g3: low d3 '8
    N39:
    gosub CLAR3
    low A3: low B3: low C3: low f3: low g3: low d3 '9
    CLAR3: 'clear 1ST DIGIT
    high A3: high B3: high C3: high d3: high e3: high f3: high g3
    N40: '0 at 1st digit
    GOSUB CLAR4
    LOW A4: LOW B4: LOW C4: LOW D4: LOW E4: LOW F4 '0
    N41: '1 AT 1ST DIGIT
    GOSUB CLAR4
    low b4: low c4 '1
    N42:
    GOSUB CLAR4
    low A4: low B4: low g4: low e4: low d4 '2
    N43:
    GOSUB CLAR4
    low A4: LOW B4: LOW C4: LOW D4: LOW G4 '3
    N44:
    GOSUB CLAR4
    LOW F4: LOW B4: LOW G4: LOW C4 '4
    N45:
    GOSUB CLAR4
    LOW A4: LOW F4: LOW G4: LOW C4: LOW D4 '5
    N46:
    GOSUB CLAR4
    LOW F4: LOW A4: LOW G4: LOW E4: LOW D4: LOW C4 'C6
    N47:
    GOSUB CLAR4
    low A4: low B4: low C4 '7
    N48:
    gosub CLAR4
    low A4: low B4: low C4: low F4: low E4: low G4: low D4 '8
    N49:
    gosub CLAR4
    low A4: low B4: low C4: low F4: low G4: low D4 '9
    CLAR4: 'clear 1ST DIGIT
    high A4: high B4: high C4: high D4: high E4: high F4: high G4
    CLEANER: 'clear all
    high a1: high b1: high c1: high d1: high e1: high f1: high g1
    high a2: high b2: high c2: high d2: high e2: high f2: high g2
    high a3: high b3: high c3: high d3: high e3: high f3: high g3
    high a4: high b4: high c4: high d4: high e4: high f4: high g4
    As I understand, this sequential access is good, but I can't use it with my PCB, need to design a new one...
    nonsense, you can map it to any configuration
    Here version with HPWM controlled color setting mode
    And by adding properly synced multiplexing, even nicer effects can be obtained. Too bad they do not make RGB 7 segment displays in manageable size or price....
    As you can see, greens are less bright than reds, this is due fact, that there are two leds in series for each color and each segment, so driving them from 5V makes green look less brighter. To achieve same level of brightness of green as red has, it needs about 5.8V, which is way too high and most likely will burn my MCU, so I'm avoiding that at all costs.
    Oct 2010
    Attachment 8887
    very nice work. thanks for sharing. I'm not going to use your code but definately it will help me understand some things.
    I've added external drivers to circuitry, so voltage now not an issue, so brightness also can be increased
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 03:01
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  5. Replies: 1
    Last Post: - 16th February 2005, 21:05
