"Variable already an alias" - is there a way to avoid this?
Results 1 to 33 of 33
Threaded View
  1. #10
    Default Re: "Variable already an alias" - is there a way to avoid this?
    I really do not understand why you may need this.
    At design time, you decide what you will connect on which ports. Then you proceed to writing the program.
    At this stage you have lines that will be defining what your circuit will do, at compile time, and what decisions your code will do at run time. Your electric connection cannot change dynamically!
    It just doesn't make sense, to me at least, why move around a LED or Buzzer, or Button from port to port at run time...
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 02:01
  2. Replies: 0
    Last Post: - 14th November 2013, 03:32
  3. Replies: 3
    Last Post: - 15th October 2012, 08:06
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:39
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
