Can PBP read optical encoder damn fast? :)
Results 1 to 40 of 47
    Default Re: Can PBP read optical encoder damn fast? :)
    Yes, it's because your particular encoder has 4 counts per detent and, as you say, sometimes it will "overshoot" the detent slightly causing the code register one count before it "springs back" into the detent position. The important thing is that the code DOES register it "springing back" so that it doesn't lose position.
    These mechanical encoders exists with either 4 counts (one quadrature cycle) per detent or 1 count (1/4 quadrature cycle) per detent. Using 1x decoding with an encoder that has 1 count per detent means you'd have to turn it 4 clicks for each increment. However, with the type of encoder you have using 1x decoding might be better.
    Absolutely agree. Code works as expected and is fast enough for manual rotation. Have not tested for faster resposne.
    The encoder indeed has a detent that produces 4x pulses so yeah. It is not appropriate for that code.
    Not the best programming techniques but uses interrupts and is fast enough for x4 encoders like ALPS with push switch used to reset the position counter.
    Based on Henrik's example and tested on 16F886.
    intcon=%10001000
    iocb=7
    Encoder VAR BYTE
    Old_Enc VAR BYTE
    Test VAR BYTE
    Dir VAR WORD          ' Must be same size as Position variable
    position    var word
    ch_a var portb.0
    ch_b var portb.1
    detent  var byte
    flag  var bit
    clear
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    wsave   var byte $70 system
            INT_Handler     RBC_INT,    _rotary,   PBP,    yes
        INT_CREATE
    @ INT_ENABLE  RBC_INT        ; Enable PortB.0 interrupt for signal reception
    rotary:
    '--------------Poll encoder and keep count -------------------
    '-------------Alternative routine with 4x decoding------------
        Encoder.0 = Ch_A
        Encoder.1 = Ch_B
        Test = Encoder ^ Old_Enc
        Dir = 0
        If Test = 1 THEN
            If Old_Enc = 0 THEN Dir = 1
            IF Old_Enc = 1 THEN DIR = -1
            IF Old_Enc = 2 THEN Dir = -1
            If Old_Enc = 3 Then Dir = 1
        IF Test = 2 THEN
            IF Old_Enc = 0 THEN DIR = -1
            IF Old_Enc = 1 THEN Dir = 1
            IF Old_Enc = 2 THEN Dir = 1
            IF Old_Enc = 3 THEN Dir = -1
        if !portb.2 then             'Reset counter
            position=0
            flag=1
        if Old_Enc <> Encoder then
            Old_Enc = Encoder
            detent=detent+1      'Increment position after 4 pulses (one detent on ALPS encoder)
            if detent = 4 then
                Position = Position + Dir
                detent=0
                flag=1
    @ INT_RETURN
    while 1
    if flag then
        hserout [#position,13,10]
        flag=0
    'other code stuff here
    wend
  1. HEDS5540 optical encoder
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 12th October 2016, 00:23
  2. how to read ky40 mechanical encoder ?
    Last Post: - 25th October 2015, 17:22
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 21:43
  4. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 16:09
  5. Damn these low power PIC and other Microcontrollers
    By keithdoxey in forum Off Topic
    Last Post: - 12th November 2006, 22:52
