Can PBP read optical encoder damn fast? :)
Results 1 to 40 of 47
    Default Re: Can PBP read optical encoder damn fast? :)
    I am a terrible programmer but have done some ISR routines that also do things fast.
    If I can do it, everyone can do it! Try it and see how it goes. After all we are still here...
    I'd select a PIC of relatively recent 18F series so the famous DT INTS-18 will support it, follow the instructions for the DT INTS and do some test. See here: http://dt.picbasic.co.uk/INT16/DTINTS-18
    Nothing to be afraid of.
    Yes I see 150Hz limitation. But as said above, I'd like to test idea first, if it is working at all.
    I couldn't help myself, had to see what I could do with just some simple, basic (no pun intended) coding. No interrupts, no hardware assist, no inline assembly language, just 33 line loop of straight PBP.
    On an 18F4520 running at 20MHz it's seems solid as a rock at 20kHz. Above 20kHz it misses the odd count when subjected to long bursts. This is with a function generetor generating bursts of "perfect" signals with 50% dutycyle so in real life it might be a little less.
    Connecting an optical encoder works fine but a mechanical one does not due to contact bounce. Using a 16bit WORD for the position counter and simple 1x decoding, pissing away 3/4 of the resoultion but that was what was asked for.
    It bit-bangs SPI data to an AD9833 but there's no math to calculate actual frequency.
    The LCD code is there for my debug purposes but I left it there just in case.
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DEFINE LCD_DREG PORTD       'LCD data port
    DEFINE LCD_DBIT 0           'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA      'LCD register select port
    DEFINE LCD_RSBIT 3          'LCD register select bit
    DEFINE LCD_EREG PORTA       'LCD enable port
    DEFINE LCD_EBIT 1           'LCD enable bit
    DEFINE LCD_RWREG PORTA      'LCD read/write port
    DEFINE LCD_RWBIT 2          'LCD read/write bit
    DEFINE LCD_BITS 8           'LCD bus size 4 or 8
    DEFINE LCD_LINES 2          'Number lines on LCD
    DEFINE LCD_COMMANDUS 3000   'Command delay time in us
    DEFINE LCD_DATAUS 40        'Data delay time in us
    FSYNC       VAR LATB.3
    SCLK        VAR LATB.4
    SDATA       VAR LATB.5
    Ch_A        VAR PortB.6
    Ch_B        VAR PortB.7
    Position    VAR WORD            ' Encoder position
    Frequency   VAR WORD            '
    AD9833      VAR WORD[5]         ' Array for data to be sent to the AD9833
    BitsToSend  VAR BYTE            ' Number of bits -1 to send to the AD9833 (max 127)
    Ch_A_Old    VAR BIT             ' Memory bit for edge-detection
    '------------------------- Init ------------------------------
    CMCON = 7
    ADCON1 = %00001111              ' No analog inputs.
    TRISB  = %11000001
    Frequency = 0
    Position = 0
    BitsToSend = 255
    PAUSE 1000
    LCDOUT $FE, 1, "AD9833..."
    ' Initialize the AD9833 as per example in AN-1070.
    ' Just to verify that we're good to go.
    ' This should make it output 400Hz with a 25MHz base clock
    AD9833[4] = $2100
    AD9833[3] = $50C7
    AD9833[2] = $4000
    AD9833[1] = $C000
    AD9833[0] = $2000
    FSYNC = 0
    For BitsToSend = 79 to 0 Step -1
        SDATA = AD9833.0[BitsToSend]
        SCLK = 0
        PAUSEUS 20
        SCLK = 1
        PAUSEUS 20
    NEXT
    FSYNC = 1
    '--------------Poll encoder and keep count -------------------
        IF Ch_A = 1 THEN
            IF Ch_A_Old = 0 THEN
                IF Ch_B = 1 THEN
                    Position = Position + 1
                    Position = Position - 1
                Ch_A_Old = 1
            Ch_A_Old = 0
    '------------- If needed, prepare to update DDS --------------
        IF Position <> Frequency THEN           ' Has the count changed since last update of the DDS?
            IF BitsToSend.7 THEN                ' Are we free to update?
                Frequency = Position
                ' See datasheet for AD9833, this is just for basic testing.
                AD9833[2] = %0010000000000000
                AD9833[1] = %0100000000000111
                AD9833[0] = Frequency
                AD9833.0[15] = 0
                AD9833.0[14] = 1
                BitsToSend = 47                 ' 3*16 = 48 but we're using this variable to index the bits so minus 1
    '---If DDS is to be updated, do it one bit per loop iteration----
        IF NOT BitsToSend.7 THEN              ' Still bits left to send ?
            FSYNC = 0                         ' Chip select
            SDATA = AD9833.0[BitsToSend]      ' Setup data
            SCLK = 0                          ' Clock low
            BitsToSend = BitsToSend - 1       ' Index next bit
            SCLK = 1                          ' Clock high
            SCLK = 1
            FSYNC = 1                          ' Chip select
    ' This is for debugging purposes.
    ' If button is pressed and LCD updated while the encoder is moved
    ' counts will obviously be missed.
    IF PortB.0 = 0 THEN
        LCDOUT $FE, 1, DEC Position, "  ", DEC Frequency, "   ", DEC BitsToSend
    Goto Main
    Excellent job Henrik.
    At the expense of a little slower response, a couple of 100nF will help a lot debouncing mechanical encoders. I used that as I did not want to make a software debouncing at that time.
    IF A=1 or B=1 AND A<>B
    Is this proper replacement for XOR statement?
    You could always write a little program to test your supposition and find out , you never know you may learn something
    TOUCH                var byte
    A   VAR TOUCH.0
    B          VAR TOUCH.1
    RES        var byte
    touch = 4
    Debug 9,"XOR TRUTH TABLE"
    Debug ,13 ,10,"A",9,"B",9,"A^B",9,"CUT",13 ,10
    while touch
        touch=touch-1
        touch=~touch
    ;CODE UNDER TEST
       IF A = 1 or  B = 1  AND A <> B THEN
           RES=1
          RES=0
       DEBUG #A,9,#B,9," ",#A^B ,9," ",#RES ,13 ,10
       touch=~touch
    WEND
    And although the little debug program of Richard's might not give you a clue, the keyword is "priority".
    Machines do not follow your thoughts. Need more detailed explanations, so parenthesis will help. See page 87 of the manual to understand why your expression is way out of what you intended to.
  1. HEDS5540 optical encoder
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 11th October 2016, 23:23
  2. how to read ky40 mechanical encoder ?
    Last Post: - 25th October 2015, 16:22
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 20:43
  4. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 15:09
  5. Damn these low power PIC and other Microcontrollers
    By keithdoxey in forum Off Topic
    Last Post: - 12th November 2006, 21:52
