Can PBP read optical encoder damn fast? :)
Results 1 to 40 of 47
    Default Re: Can PBP read optical encoder damn fast? :)
    I tried to start it at all, even at slow speeds, and looked forum for rotary encoder debug code. Most examples have things like this in it:
    OLDR = PORTB & $30 and similar, current hardware config limiting code.
    Is there a way to have "universal" rotary encoder code, which will work, if say one pin is going to PORTD.4 and another to PORTA.2 ? I'm not sure how all this XORing and ANDs can be performed across the various ports.
    Do you have hardware already on which this has to run? If that's the case then please tell us what that is which PIC and which pins are available.
    Having the encoder pins spread across two different port register will slow it down and is not ideal, two adjacent pins on the same port is prefferable. If those pins have IOC capabilities that's one way to skin it.
    You say the encoder have 60 pulses, is that 60 pulses per channel (240 edges per cm) or 15 pulses per channel (60 edges)? If it's the former and you're fine with 60 Counts per cm that makes it easier since it's just a mater of sampling channel B on the Rising edge of channel A. No qudrature decoding needed.
    I take it you've already figured out how to talk to the AD9833 or is that going to be the follow up question?
    I have not went with AD9833 yet, because if I can't run encoder, then there is no need for DDS. And by the way, some DDS code I see around the forum, so I think I can re-use it. For the encoder, this is simple encoder from inkjet printer, HEDS-9730. The ribbon has plain strips, 60 per centimeter (I've counted it under microscope). Before going with this encoder, I want to have some code running with simple, rotary, 3 pin, incremental encoder. My prototyping system has PIC16F886 on it now, and while now I can connect both pins to same port - say PORTA.1 and PORTA.2, if doing own code, I'd like to have a code, which will not be limited by same port.
    If on different port, then you will spend time on transferring the data to a temp variable and do the XOR/AND on that temp byte.
    While I know how XOR AND and other logical operations work, I can't get idea, how they are used over time based domain, as in case of encoder. I mean, where is that component, which defines the frequency of readout and pulse width and so on.
    I came up with this code idea (have not tested it yet)
    STATE: 'WAIT FOR ENCODER TO BE MOVED (STATE CHANGE)
    X=PORTB.1
    Y=PORTB.2
    PAUSE 10
    X1=PORTB.1
    Y1=PORTB.2
    IF X<>X1 OR Y<>Y1 THEN GOTO NEXTSTEP
    GOTO STATE
    NEXTSTEP:
    SOMELOOP: 'COUNTER LOOP FOR PULSE LENGTH COUNTING
    IF PORTB.1=1 THEN XIN=XIN+1 'X INCREMENT
    IF PORTB.2=1 THEN YIN=YIN+1 'Y INCREMENT
    IF PORTB.1=0 OR PORTB.2=0 THEN GOTO ANALYZE 'EXIT AND COMPARE LENGTHS
    GOTO SOMELOOP
    ANALYZE: 'DETERMINE DIRECTION AND INCREMENT CORRESPONDING VARIABLE
    IF XIN>YIN THEN
    CCW=CCW+1
    CW=CW+1
    XIN=0 'RESET VARIABLES
    YIN=0
    GOTO STATE
    Jan 2010
    Check out https://www.microchip.com/wwwproducts/en/PIC18F4431 this series has a hardware quadrature encoder feedback module that runs on it's own in the back ground.
    For optical encoder I use this:
    ; PIC18F4520
    INCLUDE "DT_INTS-14.bas"        ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"        ; Include if using PBP interrupts
    TRISA    = %00000000 ' Make all PortA pins output
    TRISB    = %11001000
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA
    define LCD_RSBIT 4
    define LCD_EREG PORTA
    define LCD_EBIT 6
    define LCD_BITS 4
    define LCD_LINES 2
    define LCD_COMMANDUS 2000
    define LCD_DATAUS 50
    ; encoder ch A PortB.6
    ; encoder ch B PortB.7
    wsave       VAR BYTE $70     SYSTEM  ; alternate save location for W
    enc_new     VAR BYTE bank0
    enc_old     VAR BYTE bank0
    enc_counter VAR word bank0
    Flag        var BYTE bank0
    asm
    INT_LIST  macro    ; IntSource,        Label,  Type, Resetflag?
            INT_Handler    RBC_INT, _enc,  ASM,  yes
        INT_CREATE     ; Creates the interrupt processor
    endasm
    ; Set variable value @ startup
    enc_new = 0
    enc_old= 0
    enc_counter = 0
    Flag = 0
    @ INT_ENABLE RBC_INT  ; enable external (INT) interrupts
    Main_Loop:
    Lcdout $fe, 1
    lcdout  Dec enc_counter
    goto Main_Loop
    enc:
    asm
        ;Read latest input from PORTB & put the value in _enc_new.
             MOVE?CB 1,_Flag
             movf    PORTB,W
             movwf  _enc_new
                                   ;Strip off all but the 2 MSBs in _enc_new.
             movlw    B'11000000'  ;Create bit mask (bits 7 & 6).
             andwf   _enc_new,F    ;Zero bits 5 thru 0.
                                   ;Determine the direction of the Rotary encoder.
             rlcf     _enc_old,F   ;left shift it into _enc_old to align bit 6 of
                                   ;_enc_old with bit 7 of _enc_new.
             movf    _enc_new,W    ;Move the contents of _enc_new to W in order to XOR.
             xorwf   _enc_old,F    ;XOR previous inputs (in _enc_old) with latest
                                   ;inputs (in W) to determine CW or CCW.
             btfsc   _enc_old,7    ;Test bit 7 of result (in _enc_old).  Skip next line
                                   ;if it is 0 (direction is CCW).
             goto    Up            ;Bit is 1 (direction is CW).  Go around Down
                                   ;and increment counter.
    Down
         ;Decrements _enc_counter because the rotary encoder moved CCW.
         ;Decrements _enc_counter (16 bit value), sets Z on exit.
            decf    _enc_counter,F      ; Decrement low byte
            incfsz  _enc_counter,W      ; Check for underflow
            incf    _enc_counter+1,F    ; Update
            decf    _enc_counter+1,F    ; Fixup
            movf    _enc_counter,W
            iorwf   _enc_counter+1,W    ; Set Z bit
        ;Add here code for the CCW LED if needed.
             goto    Continue          ;Branch around UP.
    Up
        ;Increments _enc_counter because the rotary encoder moved CW.
        ;Increments _enc_counter (16 bit value), sets Z on exit.
            incfsz  _enc_counter,W      ; Add one to low byte
            decf    _enc_counter+1,F    ; No carry (negates next step)
            incf    _enc_counter+1,F    ; Add one to high byte
            movwf   _enc_counter        ; Store updated low byte back.
            iorwf   _enc_counter+1,W    ; Set Z flag
        ;Add here code for the CW LED if needed.
    Continue
        ;Assign the latest encoder inputs (in _enc_new) to _enc_old.
             movf     _enc_new,W
             movwf   _enc_old
             INT_RETURN
        ;============ END OF THE ROTARY ENCODER CODE =====
        endasm
    Yes I checked that PIC datasheet already, but I don't see any ways to implement it in PBP, we don't have statement for encoder reading, like we have for LCDOUT or OWIN.
    I've modified my code and it works ok, but sometimes I get false readings too - say for 20 pulses of CW, I will have 2-3 pulses of CCW and vise versa
    'Lcdout $Fe, $1, "WAIT..." , DEC ENX, " ", DEC ENY
    X=ENX
    Y=ENY
    PAUSE 1
    X1=ENX
    Y1=ENY
    IF X<>X1 OR Y<>Y1 THEN GOTO SOMELOOP
    GOTO STATE
    IF ENX=1 THEN X1IN=X1IN+1 'X INCREMENT
    IF ENY=1 THEN Y1IN=Y1IN+1 'Y INCREMENT
    IF ENX=0 and ENY=0 THEN GOTO ANALYZE 'EXIT AND COMPARE LENGTHS
    PAUSE 1
    GOTO SOMELOOP
    IF X1IN>Y1IN THEN
    CCW=CCW+1
    CW=CW+1
    LCDOUT $FE, $1, "RAW", DEC Y1IN, "  ", DEC X1IN, "  "
    LCDOUT $FE, $C0, "VAL ", DEC CCW, "  ", DEC CW, "  "
    PAUSE 1
    X1IN=0 'RESET VARIABLES
    Y1IN=0
    GOTO STATE
    What stops you from writing directly to the registers?
  1. HEDS5540 optical encoder
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 11th October 2016, 23:23
  2. how to read ky40 mechanical encoder ?
    Last Post: - 25th October 2015, 16:22
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 20:43
  4. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 15:09
  5. Damn these low power PIC and other Microcontrollers
    By keithdoxey in forum Off Topic
    Last Post: - 12th November 2006, 21:52
