Crc Hserout Implementation
Results 1 to 3 of 3
    Feb 2018
    Default Crc Hserout Implementation
    Hi To All
    i,m reading about crc on this thread http://www.picbasic.co.uk/forum/showthread.php?t=11790 and crc8 implementation for this code:
    CRC      VAR BYTECRC_IDX  VAR BYTE
    CRC_IN   VAR BYTE
    CRC_Poly CON $31
    CRC8:
        FOR CRC_IDX = 0 to 7
            IF (CRC.7 ^ CRC_IN.7) THEN
                CRC = (CRC << 1) ^ CRC_Poly
                CRC = CRC << 1
            CRC_IN = CRC_IN << 1
        NEXT CRC_IDX
    X      VAR BYTE
    CRC = 0
    FOR X = 0 TO 8
        LOOKUP X,[$AD, $42, $CB, $16, $05, $06, $00, $6C, $0E], CRC_IN
        HSEROUT [HEX2 CRC_IN," "]
        GOSUB CRC8
    NEXT X
    HSEROUT ["= ",HEX2 CRC,13,10,13,10]
    CRC = 0
    FOR X = 0 TO 8
        LOOKUP X,[$AD, $42, $CC, $16, $05, $08, $00, $6C, $0C], CRC_IN
        GOSUB CRC8
    NEXT X
    This Works with the values stored previously in lookup, however this could be implemented in a similar way for Hserin or Hserout in runtime ?, searching in the forum mostly of the examples involves data previously stored on program i,m building a vending machine that process information about rs232 and the data is changing constantly my project involves a 16f1938 microcontroller, i aprreciatte any advice about this issue.
    Best Regards
    Brainless
    Default Re: Crc Hserout Implementation
    yes , the simplest way is store data to be sent or received data in a buffer before processing the crc of the buffered data
    what have you tried ?
    Feb 2018
    Hello Richard
    Thanks for reply, still don´t tried something because my first step was confirm the behavior of conversion lookup against runtime data now reading you´re explanation i´m try to build the routine to store and process data and get the properly Crc value to the entire data at the end.
    Thanks Again
    Best Regards
    Brainless
  1. Crc-16
    By Electrosolve in forum mel PIC BASIC Pro
    Last Post: - 18th June 2013, 17:11
  2. Crc
    By grich in forum mel PIC BASIC Pro
    Last Post: - 7th May 2008, 09:51
  3. MicroCode Studio 3.0.0.0 -> Implementation EasyPIC4
    By question in forum mel PIC BASIC Pro
    Last Post: - 10th February 2008, 15:34
  4. LCDOUT Implementation
    By afbecker in forum mel PIC BASIC Pro
    Last Post: - 9th March 2006, 15:48
  5. CAN Bus implementation
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 01:43
