Setting 8Mhz clock speed on PIC16F684
Results 1 to 8 of 8
    Feb 2010
    I live in the UK
    Default Re: Setting 8Mhz clock speed on PIC16F684
    Hi Richard, thanks for the reply.
    "what do you expect the result to be ?"
    I thought (and was hoping) that double the OSC speed from 4 to 8Mhz would drive the led's twice as fast, 10secs would become five at 8Mhz if you see what I mean.
    Feb 2010
    I live in the UK
    Just to add, I based my last post on this article: http:// melabs.com/resources/pbpmanual/7_0.htm
    But I may have misinterpreted it, in that I thought PAUSE 1000 with DEFINE OSC 4 internal OSC would give one second delay and pause 1000 with DEFINE OSC 8 internal OSC would give 0.5 second delay.....
    So are we saying that the above PAUSE 1000 would both cause a one second delay?
    Is it only external Xtals/resonators that throw the internal timing off?
    no not at all.
    the only time it fails is when DEFINE OSC does not match the real osc frequency.
    Feb 2010
    I live in the UK
    Thanks again Richard.
    So as long as I use DEFINE OSC X, PB knows and compensates for the change still giving the correct timings PAUSE etc?
    David
    Yes, That is correct. The PAUSE command is based on the OSC frequency. If you had an 4 Mhz. crystal connected and told PBP that the OSC was 8Mhz. the PAUSE command would give you 2 times the value entered into the PAUSE command.
    EN82fn
    Feb 2010
    I live in the UK
    Dave & Richard, thank you both for taking the time to reply, much appreciated.
  1. 18F2520 clock speed ?
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 21st August 2008, 20:01
  2. code size VS speed optimization setting?
    Last Post: - 28th April 2008, 15:38
  3. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 21:29
  4. Clock Speed
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 24th November 2007, 03:06
  5. clock speed
    By Armando Herjim in forum General
    Last Post: - 30th November 2006, 13:25
