PIC equivalent 80c51
Results 1 to 4 of 4
    Default PIC equivalent 80c51
    HI,
    Like to dust off my picbasic on a new project....so wondering if there is a pin compatible PIC equivalent to the 80c51?
    It's a 44pin Quad flat pack. Hence ideally need somethign I can lift off the original micro and replace with a PIC.
    Rob.
    Default Re: PIC equivalent 80c51
    Many Microchip devices come in 44 TQPF and QFN. But the chances of Vcc and Vss lining up are pretty low.
    PPS will be your friend (for once).
    Probably better to make a daughter board.
    George
    OK
    In addition to the PIC12_6_8F offerings, there are also dsPIC30_3 and PIC24 PICs; albeit they are not covered by PBP. I barely glanced at the 8051 data sheet, so I know virtually nothing about them. I do know the Atmel AT89S52 is a direct replacement. Microchip recently acquired Atmel, so you can work with it in either the Atmel Studio 7.0 or MPLABX IDE (but not PBP).
    There really is no shortage of 8051 dev environments, there's even Bascom if you want Basic.
    George
  1. pass pic basic pro pic from pic 16f877a to pic 16f887
    By joseluisatmega8 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2020, 16:17
  2. Replies: 5
    Last Post: - 11th October 2011, 13:47
  3. PIC16F684 equivalent with 3 ports???
    Last Post: - 6th May 2008, 10:44
  4. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
  5. 'DIG' equivalent in other Languages?
    By Art in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 22:43
