Is it possible to make unidirectional serial port via 1 pin with PBP?
Results 1 to 14 of 14
    Default Re: Is it possible to make unidirectional serial port via 1 pin with PBP?
    In theory, yes.
    In practice though it depends on what else the two chips are doing because if the sender just "speaks" randomly it's likely that the receiver will miss the message if it's doing any other work in meantime.
    You'd need implement some sort of handshake scheme where the two chips first "syncs up" before the actual serial data.
    Sender can "repeat" his "message" until user says him to stop -The idea is to allow users have various kinds of animation of OG-4 dekathron, which he selects from the setup menu. The receiver will be doing the code from OG-4 topic.
    Dec 2010
    There is nothing in the protocol that prevents one way only communications.
    I have done this many times and never had an issue.
    The receiver will need an interrupt routine to make sure nothing is missed.
    Great. Thanks. The receiver will enter "config mode" upon power up, so user can adjust whatever he needs to be changed, after exiting it, it will operate independently.
    OK
    Just for ideas, I believe the DH11 (or whatever it is) temperature & humidity sensor uses 1-wire communication. You might also look at CAN, and I2C for ideas. You would need an Open Drain pin (when in output mode), or configure a transistor/MOSFET/diode to create an OD condition from both ends.
    The basic idea is a pull-up resistor creates an "Idle High" situation. Pulling the line Low is how either side initiates communication. Using INT0 (INT1_2) or IOC you could know when to look for a transmission (ISR). Unless transmitting, the pin would be configured as an Input (TRISx.x = 1), so it is able to look for packets from the other chip. With CAN, if the Sender is attempting to send a High signal, but the line is Low, Arbitration states the other chip is also trying to communicate and the looser (the one unsuccessfully trying to send a High signal) backs out. To transmit, you would first clear the TRISx.x bit, then begin sending. When finished, set the TRISx.x bit so you can then receive on the same pin.
    You would probably have to create your own protocol, but look at how exciting a challenge that might be!
    Yeah, time to implement GPIB in PBP or FSK
    Serin2 already has handshake implemented! Why not use it instead of trying to re-invent the wheel?
    From the manual:
    SERIN2 DataPin{\FlowPin},Mode,{ParityLabel,}{Timeout, Label,}[Item...]
    Receive one or more Items on Pin in standard asynchronous format. SERIN2 is similar to the BS2 SERIN command. DataPin is automatically made an input. The optional FlowPin is automatically made an output. DataPin and FlowPin may be a constant, 0 - 15, or a variable that contains a number 0 - 15 (e.g. B0) or a pin name (e.g. PORTA.0).
    The optional flow control pin, FlowPin, may be included to help keep data from overrunning the receiver. If it is used, FlowPin is automatically set to the enabled state to allow transmission of each character. This enabled state is determined by the polarity of the data specified by Mode.
  1. Serial port data pin
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 18th July 2009, 15:13
  2. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
  3. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  4. converting USB to SERIAL port (9 pin)
    By PoTeToJB in forum USB
    Last Post: - 29th March 2006, 21:10
  5. Port pin problems
    By sgreelish in forum mel PIC BASIC Pro
    Last Post: - 8th March 2004, 18:56
