Controlling OG-4 Decathron with PBP in an efficient way.
Results 1 to 40 of 40
    Default Re: Controlling OG-4 Decathron with PBP in an efficient way.
    Thanks, this is so called "deluxe" version, with OG-4. I'm also developing simple version, with less brass and using simpler tubes. Will also make it's design plans public
    Here's fixed code. Besides code, you need also 10k pulldown resistors from transistor bases to GND.
    ;----[12F683 Hardware Configuration]--------------------------------------------
    #IF __PROCESSOR__ = "12F683"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSCIO               ; INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
    cfg&= _WDT_OFF                ; WDT disabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_OFF             ; MCLR pin function is digital input, MCLR internally tied to VDD
    cfg&= _CP_OFF                 ; Program memory code protection is disabled
    cfg&= _CPD_OFF                ; Data memory code protection is disabled
    cfg&= _BOD_OFF                ; BOR disabled
    cfg&= _IESO_ON                ; Internal External Switchover mode is enabled
    cfg&= _FCMEN_ON               ; Fail-Safe Clock Monitor is enabled
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    ANSEL = %00000000  'disable analog
    CMCON0 = 7 'disable comparators
    TRISIO=%00001000 'input config
    OSCCON = %01110111
    'Include "Modedefs.bas"
    Define	OSC	8		' Set Xtal Frequency
    '	Clk     Var	GPIO.5		' Data is clocked on rising edge of this pin            kviteli
    '	Dta  	Var	GPIO.4		' Bits are shifted out of this pin          stafilosferi
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    cik var byte  'loop variable
    x   var byte   'delay variable
    increment var byte 'incremental variable
    lop var byte  'also variable
    increment=0  'temp
    sub var byte 'intracounter variable
    sub=9
    x=22                   '22 x and 295 y for 30 second loop
    y var word 'showdelay   44 and 590 for 1 minute loop
    y=295
    'INIT tube and reset to 0
    'x=2000
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    high one
    LOW ZERO
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high zero
    low tre
    pause x
    low zero
    koka:
    if GPIO.3=0 THEN
    low tre
    low two
    low one
    high zero
    pause x
    low zero
    goto tavi
    pause 1
    GOTO KOKA
    tavi:
    'stage 1______________________________________________
    'high zero
    'pause x
    'low zero
    sub=9
    gosub sub9
    high one  'proper finish?  one and two
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y'delay for display
    low zero
    sta2:
    'stage 2 ______________________________________________
    gosub sub9
    gosub subzero
    Pause Y
    low one
    'stage 3____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    'stage 4____________________________________________
    sub=8
    gosub sub9
    gosub subzero
    gosub sub2
    Pause Y
    low tre
    'stage 5____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 6____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    'stage 7____________________________________________
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 8____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 9____________________________________________
    'X=100
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    'stage 10____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 11____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    Pause Y
    low ONE
    'stage 12____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    Pause Y
    low two
    'stage 13____________________________________________
    high tre
    pause x
    low tre
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 14____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 15____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 16____________________________________________
    high tre
    pause x
    low tre
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 17____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 18____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 19____________________________________________
    high tre
    pause x
    low tre
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 20____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 21____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 22____________________________________________
    high tre
    pause x
    low tre
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 23____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    Pause Y
    low one
    'stage 24____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 25____________________________________________
    high tre
    pause x
    low tre
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 26____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    Pause Y
    low one
    'stage 27____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 28____________________________________________
    high tre
    pause x
    low tre
    'sub=1
    'gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'x=400
    'stage 29____________________________________________
    high one
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    Pause Y
    low one
    'x=400
    'stage 30____________________________________________
    high two
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 31____________________________________________
    high zero
    pause x
    low zero
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y
    'low zero
    goto koka
    sub9: 'subroutine for spinning
    for cik=1 to sub 'amount needed for full loop
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    subzero:
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x'delay for display
    high one
    low zero 'subzero here
    sub1: 'smaller sub
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    sub2: 'even smaller sub
    pause x
    high two
    low one
    pause x
    high tre
    low two
  1. Subroutine or repeated code, which is more memory efficient?
    Last Post: - 5th June 2014, 23:38
  2. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 07:53
  3. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  4. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 14:37
  5. Is there a more efficient way?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 26th July 2005, 00:38
