Controlling OG-4 Decathron with PBP in an efficient way.
Results 1 to 40 of 40
    Default Re: Controlling OG-4 Decathron with PBP in an efficient way.
    put an oscilloscope/logic analyser on gpio.4 and see what the signal looks like or if you don't have one
    put a led on gpio.4 in lieu of whats there now if it does not change state when gpio.5 is read then whatever is on gpio.4 is loading pin excessively.
    or else your description of the problem maybe unclear or inaccurate
    there are several of these
    gosub sub9
    i cant see a sub9 anywhere in your code
    sub9 'subroutine for spinning - it is there
    The whole circuit is assembled into box and potted with epoxy, so have no access to pins, except GPIO.5, I can check it with scope if needed.
    only by mcs's good grace to call anything unknown a label, the colon is missing
    that would be me out .
    I potted it because it worked very fine, until I added that input parsing code
    I can build another one, that is not an issue...
    OK
    low
    tre
    next
    subzero:
    What is "next" doing? Is that a forgotten relic from previous versions?
    Look a bit above: for cik=1 to sub 'amount needed for full loop
    Here is the main code, from which all this started. This is simple spinner, pausing at certain position after whole loop.
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 15.05.2014                                        *
    ANSEL = %00000000
    CMCON0 = 7
    TRISIO=%00001000
    OSCCON = %01110111
    'Include "Modedefs.bas"
    Define	OSC	8		' Set Xtal Frequency
    '	Clk     Var	GPIO.5		' Data is clocked on rising edge of this pin            kviteli
    '	Dta  	Var	GPIO.4		' Bits are shifted out of this pin          stafilosferi
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    cik var word
    x   var word
    cok var word
    lop var word
    x=50
    'INIT
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    LOW ZERO
    'this loop does smooth full turn
    xoxi:
    for cik=1 to 9
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    high one  'proper finish?  one and two
    pause x
    low one
    high two
    pause x
    low two
    high zero
    low zero
    goto xoxi
    It works fine, provides smooth looped animation.
    Now let's add something. Changed TRISIO=%00101000. Code works fine. Added button check loop, and it becomes messed - triggering of certain pin no longer works.
    kuku:
    if gpio.5=0 then goto xoxi
    pause 1
    goto kuku
  1. Subroutine or repeated code, which is more memory efficient?
    Last Post: - 5th June 2014, 23:38
  2. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 07:53
  3. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  4. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 14:37
  5. Is there a more efficient way?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 26th July 2005, 00:38
