Controlling OG-4 Decathron with PBP in an efficient way.
Results 1 to 40 of 40
    Default Re: Controlling OG-4 Decathron with PBP in an efficient way.
    Yes tried new chip. Output pins are connected to MPSA42 transistor via 10K resistor.
    If I swap chip with 12F1840, will problem still exist?
    I decided to put it aside, to give my mind some rest, and back to DS3231.
    I found that it does not return seconds properly.
    Have two different example codes, they work fine for minutes and hours, but does not work for seconds - seconds increase like 02 04 08 10 12 14 16 till 28, then 29 and again increase in 2 and so on.
    SecondsMSB=BCDSeconds & $70
    SecondsMSB=SecondsMSB>>4
    SecondsLSB=BCDSeconds & $0F              '
    Seconds=(SecondsMSB*10)+SecondsLSB 'combines DECMinutes MSB and LSB
    x=RTCSEC >> 4
    Y=RTCseC // 16
    z=X*10+Y
    more than likely , you need to understand and remedy the situation.
    http://www.picbasic.co.uk/forum/showthread.php?t=15843&highlight=shadow
    http://www.picbasic.co.uk/forum/showthread.php?t=15013&highlight=shadow
    a
    nd post your code and a schematic so we don't just keep guessing
    Code is posted above.
    Schematic is simple, there are 4 MPSA42 transistors, each of which is connected via 10K resistor to corresponding ports (ZERO, ONE, TWO, TRE) as shown in code. GPIO.5 is tied via 10K resistor to VDD, and button pulls it to zero.
    Only addition to code above is
    koka:
    if GPIO.5=0 THEN 'if pin pressed
    goto tavi 'launch rotation
    pause 1
    GOTO KOKA
    and post your code and a schematic so we don't just keep guessing
    i mean post the code you are using now!
    i'm likely to make mistakes going back through several pages of add infested forum to try and patch together what i think you may be using.
    and even a hand drawn schematic makes things clearer
    OK one moment, let me finish this first, figured DS3231 error reason now, it was due to re-using variable. I need rest, serious rest
    Here it is:
    if I change TRISIO config so port 5 is no longer input and directly launch the code, it works properly.
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 15.05.2014                                        *
    ANSEL = %00000000  'disable analog
    CMCON0 = 7 'disable comparators
    TRISIO=%00101000 'input config
    OSCCON = %01110111
    'Include "Modedefs.bas"
    Define OSC 8  ' Set Xtal Frequency
    ' Clk     Var GPIO.5  ' Data is clocked on rising edge of this pin            kviteli
    ' Dta   Var GPIO.4  ' Bits are shifted out of this pin          stafilosferi
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    cik var byte  'loop variable
    x   var byte   'delay variable
    increment var byte 'incremental variable
    lop var byte  'also variable
    increment=0  'temp
    sub var byte 'intracounter variable
    sub=9
    x=44                   '22 x and 295 y for 30 second loop
    y var word 'showdelay   44 and 590 for 1 minute loop
    y=590
    'INIT tube and reset to 0
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    high one
    LOW ZERO
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high zero
    low tre
    pause x
    low zero
    koka:
    if GPIO.5=0 THEN
    goto tavi
    pause 1
    GOTO KOKA
    tavi:
    'stage 1______________________________________________
    sub=9
    gosub sub9
    high one  'proper finish?  one and two
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y'delay for display
    low zero
    sta2:
    'stage 2 ______________________________________________
    gosub sub9
    gosub subzero
    Pause Y
    low one
    'stage 3____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    'stage 4____________________________________________
    sub=8
    gosub sub9
    gosub subzero
    gosub sub2
    Pause Y
    low tre
    'stage 5____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 6____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    'stage 7____________________________________________
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 8____________________________________________
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 9____________________________________________
    'X=100
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    'stage 10____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 11____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    Pause Y
    low ONE
    'stage 12____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    Pause Y
    low two
    'stage 13____________________________________________
    high tre
    pause x
    low tre
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 14____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 15____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 16____________________________________________
    high tre
    pause x
    low tre
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 17____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 18____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 19____________________________________________
    high tre
    pause x
    low tre
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 20____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 21____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 22____________________________________________
    high tre
    pause x
    low tre
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 23____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    Pause Y
    low one
    'stage 24____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 25____________________________________________
    high tre
    pause x
    low tre
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 26____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    Pause Y
    low one
    'stage 27____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 28____________________________________________
    high tre
    pause x
    low tre
    'sub=1
    'gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'x=400
    'stage 29____________________________________________
    high one
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    Pause Y
    low one
    'x=400
    'stage 30____________________________________________
    high two
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 31____________________________________________
    high zero
    pause x
    low zero
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y
    low zero
    goto koka
    sub9 'subroutine for spinning
    for cik=1 to sub 'amount needed for full loop
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    subzero:
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x'delay for display
    high one
    low zero 'subzero here
    sub1: 'smaller sub
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    sub2: 'even smaller sub
    pause x
    high two
    low one
    pause x
    high tre
    low two
    the code compiles and runs flawlessly in proteus, thats not the issue , check your circuit
  1. Subroutine or repeated code, which is more memory efficient?
    Last Post: - 5th June 2014, 23:38
  2. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 07:53
  3. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  4. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 14:37
  5. Is there a more efficient way?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 26th July 2005, 00:38
