Controlling OG-4 Decathron with PBP in an efficient way.
Results 1 to 40 of 40
    Default Controlling OG-4 Decathron with PBP in an efficient way.
    Hello, I'm adding an OG-4 decathron tube to my open source nixie clock project. It being run by separate PIC and own power supply. The tube has following pins, which are being driven by MPSA42 transistors, controlled via PIC12F683. These pins are
    Z - reset pin,also lights up, let's call it "zero"
    A,B,C - enable pins
    So sequence is as follows:
    do
    pulse Z, then pulse A, B, C in repeating loop, 9 times, after that
    pulse A and then pulse B, to lit up remaining dots
    loop
    This code provides the spinning in clockwise direction (there are also PAUSE statements, to adjust the speed). To reverse the direction, sequence after Z should be C, B, A
    So what I want to achieve. It does 1 complete run and comes back to zero. Then starts at 1st dot at right to zero and again makes 1 complete run and comes back to 1st dot. After that, it starts from 2nd dot and makes turn till it reaches 2 again, then starts at 3 and goes to 3 and so on, including 29th dot. Then starts over
    I've developed very crude and inefficient code for that, which runs on 12F683. I only have made animation till 10th dot and it already using 1k of available chip memory. Of course, I can switch to say 12F1840, but code is still not that good - any attempt to add say 2 times making the same rotation needs complete code rewrite. So is there a way that my code can be optimized? or I have another idea, Decathron tube can be considered as a kind of shift register, so maybe there is another, more efficient approach of doing the above task?
    Here is my code
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 15.05.2014                                        *
    ANSEL = %00000000
    CMCON0 = 7
    TRISIO=%00001000
    OSCCON = %01110111
    'Include "Modedefs.bas"
    Define	OSC	8		' Set Xtal Frequency
    '	Clk     Var	GPIO.5		' Data is clocked on rising edge of this pin            kviteli
    '	Dta  	Var	GPIO.4		' Bits are shifted out of this pin          stafilosferi
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    cik var word  'loop variable
    x   var word   'delay variable
    increment var word 'incremental variable
    lop var word  'also variable
    increment=0  'temp
    sub var word 'intracounter variable
    sub=9
    x=30
    'INIT tube and reset to 0
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    LOW ZERO
    tavi:
    'stage 1______________________________________________
    sub=9
    gosub sub9
    high one  'proper finish?  one and two
    pause x
    low one
    high two
    pause x
    low two
    high zero
    pause 1000'delay for display
    low zero
    'stage 2 ______________________________________________
    gosub sub9
    gosub subzero
    low one
    'stage 3____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    high tre
    low two
    pause x
    low tre
    'stage 4____________________________________________
    sub=8
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    low tre
    'stage 5____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    low one
    'stage 6____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    high tre
    low two
    'stage 7____________________________________________
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    low tre
    'stage 8____________________________________________
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    low one
    'stage 9____________________________________________
    'X=100
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    high tre
    low two
    pause x
    'stage 10____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    low tre
    goto tavi
    sub9 'subroutine for spinning
    for cik=1 to sub 'amount needed for full loop
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    subzero:
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x'delay for display
    high one
    low zero 'subzero here
    Aug 2011
    Default Re: Controlling OG-4 Decathron with PBP in an efficient way.
    One simple thing you can do is to combine commonly occurring sequences into a sub, for example
    hl2:
        pause x
        high two
        low one
    doing that (and making variables 'byte' instead of 'word') drops it down from 1K to 330
    'device=PIC12F683
    cik var byte       'loop variable
    x   var byte        'delay variable
    sub var byte        'intracounter variable
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE     VAR     GPIO.2
    ANSEL = %00000000
    CMCON0 = 7
    TRISIO = %00001000
    OSCCON = %01110111
    sub=9
    x=30
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    LOW ZERO
    tavi:
    sub=9
    gosub sub9
    gosub hl2
    gosub hl0
    pause 1000  'delay for display
    low zero
    gosub sub9
    gosub subzero
    low one
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    low tre
    sub=8
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    low tre
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    low one
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    high tre
    low two
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    high two
    low one
    gosub hl3
    low tre
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    gosub hl3
    gosub hl1
    low one
    'X=100
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    high tre
    low two
    pause x
    low tre
    sub=6
    gosub sub9
    gosub subzero
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    gosub hl3
    gosub hl1
    gosub hl2
    gosub hl3
    low tre
    goto tavi
    hl0:
        high zero
        low two
    hl1:
        pause x
        high one
        low tre
    hl2:
        pause x
        high two
        low one
    hl3:
        pause x
        high tre
        low two
    sub9: 'subroutine for spinning
            gosub hl1
            gosub hl2
            gosub hl3
        next
        low tre
    subzero:
        gosub hl2
        high zero
        low two
        high one
    I've bound to have goofed that up somewhere so it's up to you to fix whatever I screwed up, but you get the idea.
    Yeah I already started that, but had no idea, going from word to byte will save that much space
    I'm still thinking, decathron is a ring counter/shift register, so maybe there is some other ways of controlling it....
    And stop using HIGH/LOW, those waste both time and space.
    The animation can most likely be done with two FOR loops. An outer that steps thru the starting position from 1 to 29 and an inner that "sweeps the circle" one revolution starting/stopping at the dot pointed to by the outer loop.
    If I'm not mistaken the effect you're after is similar to the the common "please wait the computer is busy" circle thingy you see on Windows systems?
    You can't do it with two FOR loops, because you have to consider the reset pin and fact that number of dots is even, but number of control pins is odd. So it is always required to add an extra step out of loop, depending on even/odd current position.
    The effect I'm making is as follows. Rotation starts from dot 1 and comes again to dot 1, stops there for a second, then quickly rotates one full loop, but stops at dot #1. Waits for a second, full spin and stop at dot #2 and so on, till it makes full turn.
    If you say so :-)
    Do you have a datasheet describing the driving signals, I'm having some difficulties understanding how it works based on your description.
    I have only Russian book about it. But principle of operation is nicely shown in animation here:
    https://threeneurons.wordpress.com/dekatron-stuff/
    And stop using HIGH/LOW, those waste both time and space....
    Well, I have some doubts about this. If it relates to output port registers I think it is necessary to use High/Low commands. Or at least this used to be the case with older versions of PBB.
    Direct control of port registers like this portb.0=1 may cause problems when the program is long because of memory page issues. I may be wrong here. Anyone?
    the only problem with high/low is that they waste time and code space setting/clearing the tris register ,every time they are invoked.
    the only issue with direct port writes once you have the tris reg set appropriately is the potential for rmw issues , especially at high clock speeds.
    always use lat regs if possible and a shadow reg otherwise if rapid sequential port manipulation of individual pins will be employed
    OK
    Most everything PIC made in the past decade features LATx Registers;
    LATB.0 = 1
    (Of course you could also insert a bit of ASM if FOSC cycles are important
    @ BANKSEL LATB
    @ BSF LATB,0
    For this particular case, speed is not an issue, since these tubes have couple of KHz max operating frequency, and in my case there are Pause 30 and Pause 1000 statements
    Run into strange problem - setting GPIO.5 as input messes with GPIO.4 - it becomes high when GPIO.5 is read, so disrupts complete code routine. I'm using TRISIO=%00100000 to make GPIO.5 as input. If I disable it as input, then other code works fine.
    OK
    In your code at the top of the page you list TRISIO=%00001000. Of course GPIO.3 is MCLR and is Input only. In the previous post you state you are having problems with TRISIO=%00100000. It's probably not your issue, but try TRISIO=%00101000.
    It does not helps. And I'm not using MCLR pin for anything except programming. Tried TRISIO=%00101000 but that does not helps. Tried disabling MCLR from config, also no change. Making a pin input creates issues with others being output.
    I tried to replace HIGH/LOW statements with TRISIO.X=1 or 0, it does not helps. In fact, say TRISIO.0=1 does not make GPIO.0 pin high.
    OK
    Did you try a new PIC? I've never seen what you're describing. Thinking something internal might be whacked.
    its a classic rmw problem.
    can also be caused by excessive load on output pin (capacitive or resitive) causing pin to not achieve proper logic level.
    Yes tried new chip. Output pins are connected to MPSA42 transistor via 10K resistor.
    If I swap chip with 12F1840, will problem still exist?
    I decided to put it aside, to give my mind some rest, and back to DS3231.
    I found that it does not return seconds properly.
    Have two different example codes, they work fine for minutes and hours, but does not work for seconds - seconds increase like 02 04 08 10 12 14 16 till 28, then 29 and again increase in 2 and so on.
    SecondsMSB=BCDSeconds & $70
    SecondsMSB=SecondsMSB>>4
    SecondsLSB=BCDSeconds & $0F              '
    Seconds=(SecondsMSB*10)+SecondsLSB 'combines DECMinutes MSB and LSB
    x=RTCSEC >> 4
    Y=RTCseC // 16
    z=X*10+Y
    more than likely , you need to understand and remedy the situation.
    http://www.picbasic.co.uk/forum/showthread.php?t=15843&highlight=shadow
    http://www.picbasic.co.uk/forum/showthread.php?t=15013&highlight=shadow
    a
    nd post your code and a schematic so we don't just keep guessing
    Code is posted above.
    Schematic is simple, there are 4 MPSA42 transistors, each of which is connected via 10K resistor to corresponding ports (ZERO, ONE, TWO, TRE) as shown in code. GPIO.5 is tied via 10K resistor to VDD, and button pulls it to zero.
    Only addition to code above is
    koka:
    if GPIO.5=0 THEN 'if pin pressed
    goto tavi 'launch rotation
    pause 1
    GOTO KOKA
    and post your code and a schematic so we don't just keep guessing
    i mean post the code you are using now!
    i'm likely to make mistakes going back through several pages of add infested forum to try and patch together what i think you may be using.
    and even a hand drawn schematic makes things clearer
    OK one moment, let me finish this first, figured DS3231 error reason now, it was due to re-using variable. I need rest, serious rest
    Here it is:
    if I change TRISIO config so port 5 is no longer input and directly launch the code, it works properly.
    ANSEL = %00000000  'disable analog
    CMCON0 = 7 'disable comparators
    TRISIO=%00101000 'input config
    OSCCON = %01110111
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    increment var byte 'incremental variable
    lop var byte  'also variable
    increment=0  'temp
    sub=9
    x=44                   '22 x and 295 y for 30 second loop
    y var word 'showdelay   44 and 590 for 1 minute loop
    y=590
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    high one
    LOW ZERO
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high zero
    low tre
    pause x
    low zero
    koka:
    if GPIO.5=0 THEN
    goto tavi
    pause 1
    GOTO KOKA
    tavi:
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y'delay for display
    low zero
    sta2:
    gosub sub9
    gosub subzero
    Pause Y
    low one
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=8
    gosub sub9
    gosub subzero
    gosub sub2
    Pause Y
    low tre
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    Pause Y
    low one
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'X=100
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=6
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 11____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    Pause Y
    low ONE
    'stage 12____________________________________________
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    Pause Y
    low two
    'stage 13____________________________________________
    high tre
    pause x
    low tre
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 14____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 15____________________________________________
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 16____________________________________________
    high tre
    pause x
    low tre
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 17____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 18____________________________________________
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 19____________________________________________
    high tre
    pause x
    low tre
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 20____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'stage 21____________________________________________
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 22____________________________________________
    high tre
    pause x
    low tre
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 23____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    Pause Y
    low one
    'stage 24____________________________________________
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    'stage 25____________________________________________
    high tre
    pause x
    low tre
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'stage 26____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    Pause Y
    low one
    'stage 27____________________________________________
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 28____________________________________________
    high tre
    pause x
    low tre
    'sub=1
    'gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'x=400
    'stage 29____________________________________________
    high one
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    Pause Y
    low one
    'x=400
    'stage 30____________________________________________
    high two
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    pause x
    high two
    low one
    Pause Y
    low two
    'stage 31____________________________________________
    high zero
    pause x
    low zero
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y
    low zero
    goto koka
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    subzero:
    pause x
    high two
    low one
    pause x
    high zero
    low two
    high one
    sub1: 'smaller sub
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    sub2: 'even smaller sub
    pause x
    high two
    low one
    pause x
    high tre
    low two
    the code compiles and runs flawlessly in proteus, thats not the issue , check your circuit
    Check for what?
    If I replace TRISIO=%00101000 with TRISIO=%00001000, it will also work fine (but without a button).
    put an oscilloscope/logic analyser on gpio.4 and see what the signal looks like or if you don't have one
    put a led on gpio.4 in lieu of whats there now if it does not change state when gpio.5 is read then whatever is on gpio.4 is loading pin excessively.
    or else your description of the problem maybe unclear or inaccurate
    there are several of these
    gosub sub9
    i cant see a sub9 anywhere in your code
    sub9 'subroutine for spinning - it is there
    The whole circuit is assembled into box and potted with epoxy, so have no access to pins, except GPIO.5, I can check it with scope if needed.
    only by mcs's good grace to call anything unknown a label, the colon is missing
    that would be me out .
    I potted it because it worked very fine, until I added that input parsing code
    I can build another one, that is not an issue...
    OK
    low
    tre
    next
    subzero:
    What is "next" doing? Is that a forgotten relic from previous versions?
    Look a bit above: for cik=1 to sub 'amount needed for full loop
    Here is the main code, from which all this started. This is simple spinner, pausing at certain position after whole loop.
    ANSEL = %00000000
    CMCON0 = 7
    TRISIO=%00001000
    OSCCON = %01110111
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    cik var word
    x   var word
    cok var word
    lop var word
    x=50
    'INIT
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    LOW ZERO
    'this loop does smooth full turn
    xoxi:
    for cik=1 to 9
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    pause x
    low one
    high two
    pause x
    low two
    high zero
    low zero
    goto xoxi
    It works fine, provides smooth looped animation.
    Now let's add something. Changed TRISIO=%00101000. Code works fine. Added button check loop, and it becomes messed - triggering of certain pin no longer works.
    kuku:
    if gpio.5=0 then goto xoxi
    pause 1
    goto kuku
    Tried to change control pin to GPIO.3 (MCLR). No change, as long as reading of port occurs in software, the glitches come on.
    I think I've nailed it, and it appears to be both software and hardware issue. If input is activated, at startup, there is small pulse on random pin, which is short enough for not to be noticeable by eye, but enough to trigger dekathron (traced using scope). Solved by pulling down outputs via 10K to GND. S
    Almost there
    Truly amazing!
    Thanks, this is so called "deluxe" version, with OG-4. I'm also developing simple version, with less brass and using simpler tubes. Will also make it's design plans public
    Here's fixed code. Besides code, you need also 10k pulldown resistors from transistor bases to GND.
    ;----[12F683 Hardware Configuration]--------------------------------------------
    #IF __PROCESSOR__ = "12F683"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSCIO               ; INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
    cfg&= _WDT_OFF                ; WDT disabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_OFF             ; MCLR pin function is digital input, MCLR internally tied to VDD
    cfg&= _CP_OFF                 ; Program memory code protection is disabled
    cfg&= _CPD_OFF                ; Data memory code protection is disabled
    cfg&= _BOD_OFF                ; BOR disabled
    cfg&= _IESO_ON                ; Internal External Switchover mode is enabled
    cfg&= _FCMEN_ON               ; Fail-Safe Clock Monitor is enabled
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    TRISIO=%00001000 'input config
    OSCCON = %01110111
    ZERO    var     GPIO.0
    ONE     VAR     GPIO.4
    TWO     VAR     GPIO.1
    TRE   VAR      GPIO.2
    increment=0  'temp
    sub=9
    x=22                   '22 x and 295 y for 30 second loop
    y=295
    'x=2000
    inika:
    LOW ONE
    LOW TWO
    LOW TRE
    HIGH ZERO
    PAUSE x
    high one
    LOW ZERO
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high zero
    low tre
    pause x
    low zero
    koka:
    if GPIO.3=0 THEN
    low tre
    low two
    low one
    high zero
    pause x
    low zero
    goto tavi
    pause 1
    GOTO KOKA
    tavi:
    'high zero
    'pause x
    'low zero
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    low zero
    sta2:
    gosub sub9
    gosub subzero
    Pause Y
    low one
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=8
    gosub sub9
    gosub subzero
    gosub sub2
    Pause Y
    low tre
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    Pause Y
    low one
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=7
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    'X=100
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    high tre
    low two
    pause x
    low tre
    sub=6
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    Pause Y
    low ONE
    low tre
    sub=6
    gosub sub9
    gosub subzero
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    Pause Y
    low two
    high tre
    pause x
    low tre
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    Pause Y
    low tre
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause x
    high two
    low ONE
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    sub=5
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    high tre
    pause x
    low tre
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    sub=4
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    high tre
    pause x
    low tre
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    Pause Y
    low one
    sub=3
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    high tre
    pause x
    low tre
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    Pause Y
    low one
    sub=2
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    Pause Y
    low two
    high tre
    pause x
    low tre
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause X
    high one
    low tre
    pause X
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    Pause Y
    low one
    sub=1
    gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    Pause Y
    low two
    high tre
    pause x
    low tre
    'sub=1
    'gosub sub9
    gosub subzero
    gosub sub2
    pause x
    gosub sub1
    high one
    low tre
    gosub sub2
    pause x
    gosub sub1
    gosub sub1
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    Pause Y
    low tre
    'x=400
    high one
    pause x
    high two
    low one
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    Pause Y
    low one
    'x=400
    high two
    pause x
    high zero
    low two
    pause x
    low zero
    sub=9
    gosub sub9
    high one
    pause x
    high two
    low one
    Pause Y
    low two
    high zero
    pause x
    low zero
    sub=9
    gosub sub9
    pause x
    low one
    high two
    pause x
    low two
    high zero
    Pause Y
    'low zero
    goto koka
    high one
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    low tre
    next
    subzero:
    pause x
    high two
    low one
    pause x
    high zero
    low two
    high one
    sub1: 'smaller sub
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    high one
    low tre
    pause x
    high two
    low one
    pause x
    high tre
    low two
    pause x
    pause x
    high two
    low one
    pause x
    high tre
    low two
  1. Subroutine or repeated code, which is more memory efficient?
    Last Post: - 5th June 2014, 23:38
  2. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 07:53
  3. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  4. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 14:37
  5. Is there a more efficient way?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 26th July 2005, 00:38
