4 -20mA Analogue input help
Results 1 to 9 of 9
    Alabama,USA
    Default Re: 4 -20mA Analogue input help
    Andy, a 250 precision Res is what I always used in the field for years. Just check the voltage across the res with the pic. I would think it depends on the accuracy you need.
    wayne
    I'd recommend 0.1% or best and also an input protection for overvoltage on the PIC side. If for any reason the ground side of the resistor is disconnected, it is certain that the PIC will be destroyed.
  1. Creating 4 to 20MA ?
    By amgen in forum Off Topic
    Last Post: - 3rd May 2014, 22:45
  2. 32 LEDs with less than 20mA
    By Demon in forum Off Topic
    Last Post: - 23rd January 2014, 03:28
  3. 4-20mA output using PWM
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 8th December 2007, 09:45
  4. Pin as Digital and Analogue
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 16th July 2006, 09:41
  5. 4-20mA to 0-5V configuration
    By leonel in forum General
    Last Post: - 31st August 2005, 12:33
