Speeding up a loop?
Results 1 to 14 of 14
    Default Re: Speeding up a loop?
    (ex: =x*22/14-47/21249*x^2-7*x^3/(2^16) with x in binary radians has an error of about 1.7%, assuming I can implement it without being killed time-wise with DIV32)
    on a esp8266 @ 160mhz clk or a esp32 , pic16fxx never
    Aug 2011
    audio tones up to 10kHz on a 16Fxx architecture with a 20Mhz OSC
    16Fxx isn't the best choice
    For comparison:
    16Fxx @ 20MHz executes instructions at 5 MIPS,
    16F1xxxx @ 32MHz -> 8 MIPS,
    18F @ 64MHz -> 16 MIPS
    Looking back at your original pseudo code with lookup table SINB array in ram:
    loop1:
    lookbyte=timebyte and 31
    ampvar=SINB(lookbyte)
    PORTB=ampvar
    timebyte=timebyte+1
    goto loop1
    On a PIC18F @ 64MHz this executes in 1us/loop (1MHz update rate)
    If you put the SINB table in ROM (which is more likely) it slows down to 1.25us/loop (800KHz update rate)
    I didn't do those evaluations using PBP, so I don't know if it's much slower than that.
    a 16f648a@20mhz just passes 8khz with a 32 step lu in asm for a 4 bit r2r ladder on portb
    my lu values may be dodgy i just guessed them, result looks awful @ any freq
    #CONFIG  __config  _INTOSC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _BODEN_ON & _LVP_OFF & _DATA_CP_OFF & _CP_OFF
    DEFINE OSC 20
    inx var byte  bank0
    trisb=%11110000
    goto overasm
    asm
    table
        addwf   PCL, F
        retlw    8
        retlw 	 9
        retlw    10
        retlw 	 11
        retlw    12
        retlw 	 13
        retlw    14
        retlw 	 14
        retlw 	 15
        retlw    14
        retlw 	 14
        retlw 	 13
        retlw    12
        retlw 	 11
        retlw    10
        retlw 	 9
        retlw    8
        retlw    6
        retlw 	 5
        retlw 	 4
        retlw    3
        retlw    2
        retlw 	 1
        retlw 	 1
        retlw 	 0
        retlw 	 1
        retlw 	 1
        retlw    2
        retlw    3
        retlw 	 4
        retlw 	 5
        retlw    6
    _lu
        movf _inx ,w
        call table
        MOVE?AB PORTB
    overasm:
    inx=0
    loopp:
    CALL lu
     inx=inx+1
     inx =inx&31
    goto loopp
    There is another approach. Check this video.
    https://www.youtube.com/watch?v=ophqt_RmiS0
    C
    ode in description.
    This guy has done unbelievable things with low end PIC and also a color video game with multi channel sound and VGA output on a PIC18F2550!
    http://pic24.ru/doku.php/en/osa/articles/vga_game
    Using an RTOS...
    Yeah, in his creations, 16F690 outperforms some guys with RPI
    I dare to say that he is a Case Study! Wish I was proficient in C to run through his code.
  1. Do Loop
    By skybox in forum mel PIC BASIC Pro
    Last Post: - 27th December 2012, 00:45
  2. Speeding up the PIC SPI
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 20th April 2011, 16:27
  3. Speeding up HID
    By waynepauly in forum USB
    Last Post: - 17th April 2008, 23:14
  4. Needing help with speeding up paralel port
    By Kristjan in forum mel PIC BASIC
    Last Post: - 7th November 2007, 13:47
  5. While LOOP
    By actionplus in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 14:59
