Code:#CONFIG cfg1 = _INTRC_OSC_NOCLKOUT ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN cfg1&= _WDT_ON ; WDT enabled cfg1&= _PWRTE_OFF ; PWRT disabled cfg1&= _MCLRE_OFF ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD cfg1&= _CP_OFF ; Program memory code protection is disabled cfg1&= _CPD_OFF ; Data memory code protection is disabled cfg1&= _BOR_OFF ; BOR disabled cfg1&= _IESO_ON ; Internal/External Switchover mode is enabled cfg1&= _FCMEN_ON ; Fail-Safe Clock Monitor is enabled cfg1&= _LVP_OFF ; RB3 pin has digital I/O, HV on MCLR must be used for programming cfg1&= _DEBUG_OFF ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins __CONFIG _CONFIG1, cfg1 cfg2 = _BOR40V ; Brown-out Reset set to 4.0V cfg2&= _WRT_OFF ; Write protection off __CONFIG _CONFIG2, cfg2
