DT's INT's on 16F1936 an other stuff
Results 1 to 6 of 6
    Default Re: DT's INT's on 16F1936 an other stuff
    I Used in the past a 1939 one, and the first compilation had a message that I should add this:
    wsave var byte $70 system
    So, if you really need to add something, the compilation will give you the appropriate message.
    Regarding the Serout thing, if you show us your code maybe we can give an explanation.
    Alabama,USA
    Thanks for the reply. So I feel better about the interrupts. Serout, ok.
    asm
     __config _CONFIG1,_FOSC_INTOSC & _CLKOUTEN_OFF & _MCLRE_ON & _BOREN_OFF & _WDTE_OFF & _FCMEN_OFF & _CP_OFF & _CPD_OFF & _IESO_OFF
     __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_LO
    endasm
    define  osc 8
        OSCCON=%01110000   ;1110=8Mhz
        ANSELA=0
        ANSELB=0
        ADCON0=0
        PortA=0
        PortB=0
        PortC=0
        TrisA=0
        TrisB=0
        TrisC=0
    Start:
        toggle LatA.1
        toggle LatA.1
        serout2 USB_Tx,188, ["    Hello USB World",13,10]     'working 188 at 9600baud on com15 @8Mhz
        pause 3000
        goto Start
    At mode 84 I'm getting 19200baud. Beats me what is going on. Of course if its working fine, not a big deal.
    Wayne
    there the problem
    define osc 8
    should be
    define OSC 8
    Alabama,USA
    thanks Richard, I try that out. thats something I never thought about.
    Wayne
    Alabama,USA
    Changing "osc" to "OSC" did the trick. Com now acting as it should.
    Thanks.
  1. Program works!, however dont understand some DT-INT stuff.
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2013, 07:13
  2. Capacitive sensing module on 16f1936
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 25th April 2010, 15:17
  3. 16f1936
    Last Post: - 24th April 2010, 11:03
  4. Using both hardware int and Timer Int together?
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 02:09
  5. 16F1936 doesn't seem to be supported?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 17th October 2009, 16:56
