Re: Compare value ...
if your lm335 setup was used you need to subtract the offset
eg
samples=0
FOR sample = 1 TO 10 'Take 10 samples
ADCIN 0, temp 'Read AN0 into temp variable
samples = samples + temp
PAUSE 40 ' Wait 1/4 seconds per reading
NEXT sample
temp = (samples/10) -558 'subtract 2.73 v offset count
temperature= temp */ quanta
LCDOUT $FE, 1 ' cancella LCD
lcdout "Temp ",dec2 (temperature/10),".", dec1 (temperature//10),$DF,"C"
lcdout $FE, $C0,"temp raw ", dec temp
If temperature > (Tmax*10) then
rele=1
rele=0
Endif
