Compare value ...
Page 1 of 2 12 LastLast
Results 1 to 40 of 69
    Apr 2020
    Default Compare value ...
    Hi good morning everyone,
    i have a little project on PIC16F88 whit LM35.
    When temperature go over Tmax Portb.6 go High.
    I don't understand how to compare values
    On the lCD display i have 3 value
    Temp from Lm35
    Tmax from eprom
    Tmin from eprom
    but i don't undesrstand why portb.6 go always High also if the temperature Tmax is low
    thank you
    the code is
    temp var word
    temperature var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Read 0,DatoEE
    Tmin=DatoEE
    Read 1,DatoEE
    Tmax=DatoEE
    temp = 0 'Clear temp register
    temperature = 0 'Clear temperature register
    sample = 0 'Clear sample register
    samples = 0 'Clear samples register
    FOR sample = 1 TO 20 'Take 20 samples
    ADCIN 0, temp 'Read AN0 into temp variable
    samples = samples + temp
    PAUSE 50 ' Wait 1/4 seconds per reading
    NEXT sample
    temp = samples/20 'Average over 20 samples (Every 5 seconds)
    temperature= (temp*10) */ quanta
    Pause 200 ' Timeout for LCD to settle
    LCDOUT $FE, 1 ' cancella LCD
    LCDOUT $FE, 2 ' ritorna al primo carattere
    lcdout $FE, 2, "Temp ",dec2 (temperature/100),".", dec1 (temperature//100),$DF,"C"
    lcdout $FE, $C0, "Tmin ",#Tmin DIG 1,#Tmin Dig 0," Tmax ",#Tmax DIG 1,#Tmax Dig 0
    If temperature > Tmax then
    PORTA.6=1
    Endif
    Default Re: Compare value ...
    DatoEE is never defined
    i see that no data is stored to eeprom therefore tmax and tmin = 255
    then --
    PORTA.6=1
    Endif
    why would porta.6 change if temperature < Tmax your code only sets the pin it never clears it
    the initial state of pin should also be set , there is no code visible to set trisb either
    PORTA.6=1
    PORTA.6=0
    Endif
    this makes me wonder what your actual fosc is , you posted no config section and there is no OSC definition
    Apr 2020
    Hi, Forgive me, your questions are legitimate, I tried to post a surrogate code so as not to stretch too much, but I think I have created confusion.
    anyway :
    ' EEPROM Locations
    DATA @0,16 ' 16 Tenp min.
    DATA @1,30 ' 30 Temp Max.
    then temp is 20 to 24 °C (ambiental)
    Tmax is set 30°C
    the configuration is
    ' -------- bit a bit controllo 0=output 1=input
    INTCON = 0 ' NO INTERRUPT
    ADCON1 = %10001110 '
    ADCON0 = %00000101 'Disable Converter Module
    ANSEL = %00000001 'Disable Inputs Tranne AN0
    OSCCON = %01100000 'Internal RC set to 4MHZ
    CMCON = 7 '
    '76543210
    TRISA = %10111111 ' impostazioni INP/OUT
    TRISB = %00000000 ' delle porte
    the string
    only reports an incorrect comment
    so my problem is, i believe:
    temperature is a word
    Tmax is a byte
    and I don't understand how compare the values
    Apr 2020
    anyway :
    ' EEPROM Locations
    Tmax is set 30°C
    ADCON1 = 001110 '
    ADCON0 = 000101 'Disable Converter Module
    ANSEL = 000001 'Disable Inputs Tranne AN0
    OSCCON = 100000 'Internal RC set to 4MHZ
    CMCON = 7 '
    '76543210
    TRISA = 111111 ' impostazioni INP/OUT
    TRISB = 000000 ' delle porte
    the string
    Tmax is a byte
    Apr 2020
    anyway :
    ' EEPROM Locations
    Tmax is set 30°C
    CMCON = 7 '
    '76543210
    the string
    Tmax is a byte
    Try:
    1.
    ADCON0=%10000101
    while !adcon0.2:wend
    2.
    Display your variables on LCD or a serial port to be sure what values they are
    Apr 2020
    Try:
    1.
    ADCON0= 000101
    with this the Pic16F88 not working
    2.
    Display on LCD
    24.5 °C
    Tmin 16 Tmax 30
    My problem is, i think:
    Tmax is a byte
    Don't you see? You display a decimal number but the number is in fact 245 and not 24.5!
    So, maybe you can use word variables and multiply them by 10 so you can compare 245 to 160 and 300.
    My first suggestion was to make sure that bit 0 of ADCON0 was set. It needs some time and if you go fast to start ADC, the module might not work as expected. I am sorry that I made the mistake of bit 0 to 2. Please include it as this:
    ADCON0=%10000101
    while !adcon0.0:wend
    I would not set bit 2 at this stage but anyway.
    Apr 2020
    ADCON0=000101
    OK, Perfect this work well now
    I have modified code in this mode, but don't work yet
    If temperature > (Tmax*10) then
    PORTA.6=1
    PORTA.6=0
    Endif
    PORTA.6 go high when power on after showing the values on the display
    NOTE :
    The variables are still "temperature WORD" and "Tmax BYTE". I tried to change Tmax from BYTE to WORD in the declaration area but it gives me an error when compile
    You should make it word. 30*10=300 > than a byte can hold.
    Also better make the multiplication outside the comparison.
    Use the LCD as a monitor to check your values.
    About compilation, I guess it is a syntax error thing.
    Apr 2020
    hi,
    I have define Tcomp VAR WORD
    and now i have :
    tcomp=tmax*100
    lcdout $FE, 2,   "Temp. ",dec2 (temperature/100),".", dec1 (temperature//100),$DF,"C "
    lcdout $FE, $C0, "Tmax ",#Tmax DIG 1,#Tmax Dig 0," Tco ",dec2 (Tcomp/100),".", dec1 (Tcomp//100)
    On display i see :
    Temp. 23.5°C
    Tmax 30 Tco 30.0
    And PORTA.6 go at 1 the same
    Try this:
    ADCON0 = %000101 'Disable Converter Module
    CMCON = 7
    TRISA = %10001111 ' impostazioni INP/OUT
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    sample = 1 'Clear sample register
    PORTA.6=0
    do
    samples=0
    NEXT sample
    If temperature/1000 > Tmax then
    PORTA.6=1
    PORTA.6=0
    Endif
    loop
    Apr 2020
    Quote Originally Posted by louislouis View Post
    Try this:
    ADCON1 = 001110 '
    ADCON0 = 0101 'Disable Converter Module
    CMCON = 7
    TRISA = 001111 ' impostazioni INP/OUT
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    PORTA.6=0
    do
    samples=0
    NEXT sample
    PORTA.6=1
    PORTA.6=0
    Endif
    loop
    it's all very strange!
    Testing the code with temperature / 1000 in the same way PORTA.6 goes ON
    Not even dividing by 1000 is it possible to obtain the right comparison
    Then I added the Do .. loop and everything went crazy.
    The room temperature changed with each cycle and the DOOR. 6 went its own without ON and OFF criteria without considering the temperature.
    Pplease post the whole code.
    Apr 2020
    '*  Name    : 16F88_LM235.BAS                                   *
    '*  Author  :                                    *
    '*  Notice  : Copyright (c) 2020                                *
    '*  Date    : 04/04/2020                                        *
    'PIC 16F88
    '    Hardware Assignments
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    DEFINE LCD_DREG PORTB       'Porta B DATA OUT
    DEFINE LCD_DBIT 4           '0 --> Bit 0-3 : 4 --> Bit 4-7
    DEFINE LCD_RSREG PORTB      'LCD register select port - Porta B --> RS
    DEFINE LCD_RSBIT 2          'LCD register select bit  - Pin RS B2
    DEFINE LCD_EREG PORTB       'LCD enable port - Porta B --> EN
    DEFINE LCD_EBIT 3           'LCD enable bit - Pin EN B3
    DEFINE LCD_BITS 4           'LCD bus size 4 or 8
    DEFINE LCD_LINES 2          'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000   'Command delay time in us
    DEFINE LCD_DATAUS 50        'Data delay time in us
    '    EEPROM Locations Codice ASCII es. a=97 b=98 c=99 ...
    '*****  SETTAGGIO PORTE
    '      VAR      PORTA.0     'LM235M            Pin 17
    IncButton    VAR    PORTA.1     'SW          Pin 18
    DecButton    VAR    PORTA.2     'SW          Pin 1
    SetButton    VAR    PORTA.3     'SW          Pin 2
    '      VAR    PORTA.4     '                  Pin 3
    '      VAR    PORTA.5     '                  Pin 4
    Rele   VAR    PORTA.6     '                  Pin 15
    '      VAR    PORTA.7     '                  Pin 16
    '       Var       PORTB.0   '                   Pin  6
    '       var    PORTB.1   '                   Pin  7
    l_rs    var       PORTB.2   'LCD  sig. RS       Pin  8
    l_en    Var    PORTB.3   'LCD sig. E         Pin  9
    l_d4    var       PORTB.4   'LCD 4              Pin 10
    l_d5    var    PORTB.5   'LCD 5              Pin 11
    l_d6    var    PORTB.6   'LCD 6              Pin 12
    l_d7    var    PORTB.7   'LCD 7              Pin 13
    '---------Define ADCin Parameters
    DEFINE ADC_BITS 10      'set number of bits in result
    DEFINE ADC_CLOCK 3      'set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50  'Set sampling time in uS
    '    RAM Assignments and Variables
    CounterA    var byte    ' General purpose Variable
    CounterB    var byte    ' General purpose Variable
    CounterC    var byte    ' General purpose Variable
    temp        var word
    samples     var word
    Dummy       var word
    sample      VAR BYTE
    quanta      con 1250
    DatoEE      var byte
    Tmax        VAR Byte
    Tmin        VAR Byte
    Tcomp       VAR word
    Grade       var Byte
    TimeOut     var word    ' Variable for SetUp Menu Time-Out
    START:
    ADCON1 = 001110   '
    ADCON0=  000101   'Disable Converter Module
    while !adcon0.0:wend ' Attende che il convertitore sia spento prima di fare il resto
    CMCON  = 7           '
            '76543210
    ' Per utilizare i pin RA6 ed RA7 come I/O bisogna impostare lo switch in fase
    ' di programmazione Oscillotar come "INTRC_IO"
      PORTA.6=0
    '    Leggi Dati dalla EEPROM
     Read 0,DatoEE
     Tmin=DatoEE
     Read 1,DatoEE
     Tmax=DatoEE
    Lcdout $FE, 1           'Clear screen
    MAIN:
    'Subroutine to measure temp
    TEMP_READ:
    do
    sample = 0
    NEXT sample
        If temperature> TMax then
          PORTA.6=1
          PORTA.6=0
        Endif
        'lcdout $FE, $C0, "Tmax ",#Tmax DIG 1,#Tmax Dig 0," Tco ",dec2 (Tcomp/100),".", dec1 (Tcomp//100)
    loop
    goto MAIN
    Try this:
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    CMCON = 7
    Dummy       var word
    DatoEE      var byte
    Tcomp       VAR word
    Grade       var Byte
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    rele=0
    samples=0
    PAUSE 40 ' Wait 1/4 seconds per reading
    NEXT sample
    rele=1
    rele=0
    Endif
    On your last program, you still have in the room temperature a 3 digit value, say 250 and compare it with the Tmax that is 30.
    If temperature is 250 and TMax is 30 what is the result? Portb.6 always set as you requested.
    Try this and see if relay makes 2 clicks at the start of the program and then rest of the program works as expected.
    If it does not click, then your port has a problem. Search other things...
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    temp        var word
    samples     var word
    Dummy       var word
    sample      VAR BYTE
    quanta      con 1250
    DatoEE      var byte
    Tmax        VAR Byte
    Tmin        VAR Byte
    Tcomp       VAR word
    Grade       var Byte
    START:
    for sample =0 to 3
        toggle portb.6
        pause 250
    next sample
    ADCON1 = 001110   '
    CMCON  = 7           '
            '76543210
      PORTA.6=0
     Read 0,DatoEE
     Tmin=DatoEE
     Read 1,DatoEE
     Tmax=DatoEE
    MAIN:
    TEMP_READ:
    do
    sample = 0
    NEXT sample
        temperature=temperature/10
          PORTA.6=1
          PORTA.6=0
        Endif
    loop
    goto MAIN
    for a Temperature of 30 deg the temperature var would equal 3000 , what 3 digit number are we talking about, the display is to two
    decimal points the comparison must be on equal terms
    If temperature > (Tmax*100) then
    rele=1
    rele=0
    Endif
    or
    If (temperature/100) > Tmax then
    rele=1
    rele=0
    Endif
    Yeah Richard. I missed that.
    Also he must check if the port is working.
    Apr 2020
    Hi, I added the loop at the beginning of the program:
    for sample = 0 to 3
        rele=1
        rele=0
    next sample
    Yours was too fast and I didn't hear the clicks. It is now OK, at start-up three times the relay turns ON / OFF, then the display appears.
    As always, however, dividing the variable "temperature" by 10 or 100 and multiplying the variable "Tmax" by 10 or 100 the comapration between the two variables fails. and the end result is that the relay goes ON despite the Tmax is set to 30 and the value read by the sensor is 24 ° C (or at least I think, I say 24 ° C because it is what comes out on the display giving the string
    lcdout $ FE, 2, "Temp", dec2 (temperatures / 100), ".", dec1 (temperatures // 100), $ DF, "C")
    If I try to show the pure "Temperature" variable on the display like this:
    lcdout $ FE, $ C0, "TEmpe", temperatures
    an ASCII character appears on the display which changes as the temperature changes.
    I'm currently running this code
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    ADCON1 = 001110 '
    CMCON = 7
    Dummy       var word
    DatoEE      var byte
    Tcomp       VAR word
    Grade       var Byte
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    for sample = 0 to 3
        rele=1
        rele=0
    next sample
    'rele=0
    samples=0
    NEXT sample
    lcdout $FE, $C0," TEmpe", temperature
    Tmax=Tmax*100
    rele=1
    rele=0
    Endif
    Tmax=Tmax*100  you cannot do this ,Tmax is a byte var
    rele=1
    rele=0
    Endif
    this will work the pbp inline intermediate results are word sized
    rele=1
    rele=0
    Endif
    Apr 2020
    [CODE]
    rele=1
    rele=0
    Endif
    I tried, but nothing changes
    my code now is :
    ​'****************************************************************'*  Name    : 16F88_LM235.BAS                                   *
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    ADCON1 = 001110 '
    CMCON = 7
    Dummy       var word
    DatoEE      var byte
    Tcomp       VAR word
    Grade       var Byte
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    for sample = 0 to 3
        rele=1
        rele=0
    next sample
    'rele=0
    samples=0
    NEXT sample
    rele=1
    rele=0
    Endif
    what does this line display the temperature value as ?
    Apr 2020
    ASCII code, one strange character, and it changes every time the temperature changes
    lcdout $FE, $C0," TEmpe", dec temperature
    removing all the unused/unecessary stuff " just noise" , using a proper config and displaying a result more in keeping with lm35 accuracy
    this works just fine
    '****************************************************************'*  '*  Name    : 16F88_LM235.BAS                                   *
    '*  Author  :                                    *
      __config  _CONFIG1, _INTRC_IO & _WDT_ON & _PWRTE_OFF & _MCLR_ON & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_PROTECT_OFF & _DEBUG_OFF & _CCP1_RB0 & _CP_OFF
      __config  _CONFIG2, _FCMEN_ON & _IESO_ON
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    adcon1.7=1
    ANSEL = %000001 'Disable Inputs Tranne AN0
    TRISB = 0 ' delle porte
    DEFINE LCD_EBIT 3           'LCD enable bit - Pin EN B3DEFINE LCD_BITS 4           'LCD bus size 4 or 8
    DEFINE LCD_LINES 2          'Number lines on LCD DEFINE LCD_COMMANDUS 2000   'Command delay time in us
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    rele=0
    samples=0
    NEXT sample
    temperature= temp */ quanta
    lcdout $FE, 2, "Temp ",dec2 (temperature/10),".", dec1 (temperature//10),$DF,"C"
    rele=1
    rele=0
    Endif
    I think, You want this:
    Here is a Richard's corrected and tested code. I hope it will be works:
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    adcon1.7=1
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    rele=0
    sample = 1
    samples= 0
    NEXT sample
    lcdout $FE, 2, "Temp ",dec2 (temperature/10),".", dec1 (temperature/10),"C"
    lcdout $FE, $C0, "Tmin ",#Tmin, " Tmax ",#Tmax
    rele=1
    rele=0
    Endif
    Apr 2020
    '*  Author  :                                    *
    'PIC 16F88
    ' LCD circuitery
    '01     - Vss (GND)
    '02     - Vdd (+5V)
    '08 RS  - PORTB.2
    '09 E   - PORTB.3
    '10 DB4 - PORTB.4
    '11 DB5 - PORTB.5
    '12 DB6 - PORTB.6
    '13 DB7 - PORTB.7
    adcon1.7=1
    ANSEL = 0001 'Disable Inputs Tranne AN0
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    rele=0
    sample = 1
    samples= 0
    NEXT sample
    rele=1
    rele=0
    Endif
    Your video is OK!
    and the code is similar to mine, except for the initial strings.
    without too much hesitation, however, I did copy and paste of your source in my compiler
    Microcode Studio Plus 3.0.0.5
    and as soon as I tried to issue the compile command it gave me errors.
    ERROR Line 11: Syntax error. (louislouis.pbp)
    ERROR Line 12: Syntax error. (louislouis.pbp)
    ERROR Line 13: Redefiniton of LABEL __config. (louislouis.pbp)
    ERROR Line 13: Syntax error. (louislouis.pbp)
    ERROR Line 14: Syntax error. (louislouis.pbp)
    What are all those strings? why won't my compiler accept them?
    did you have set the correct microcontroller to 16F88 in microcodestudio?
    Apr 2020
    here the Screenshoot
    and if you take away the config part, it compiles without errors?
    Copy and paste this, and try to compile.
    define osc 4
    adcon1.7=1
    temp var word
    samples var word
    sample VAR BYTE
    quanta con 1250
    Tmax VAR byte
    Tmin VAR byte
    Tmin=16
    Tmax=30
    START:
    rele=0
    sample = 1
    samples= 0
    NEXT sample
    rele=1
    rele=0
    Endif
    Apr 2020
    Yes, compile without problems
    If I understand correctly, that's what I do when programming the chip, I set the fuses like this
    Yes. And now it runs OK?
    Apr 2020
    No, I have always used fuses since the first moment I started creating the project.
    I'm going crazy for this, I also changed PBP to version 2.47. I don't know what to think anymore.
    it is evident that I have a problem, but I cannot attribute to what.
    1) PBP compiler, tested with 2 versions 2.60 and 2.47
    2) IDE MicroCode, I wouldn't say.
    3) Microcontroller (the chip) cannot be, because if I pilot the door with the command PORTB.6 = 1 and PORTB.6 = 0 the relay attacks and disconnects regularly.
    4) the BYTE or WORD variables, but I also tried to change the reference value by declaring them both as WORD.
    5) The firmware is the same
    6) The programmer?
    What kind of programmer do you use? What is your programming process?
    First you compile in MCSP and then take the compiled HEX file and program to PIC with your picprogrammer? Or? How you program the PIC?
    Here is the compiled HEX file. Take it in to your programmer and program your PIC. It must run.
    Apr 2020
    It was a long time since I worked there, I pulled out old tools because I stopped at work for the "Corona Virus" and I wanted to have some fun.
    Some time ago I used a self-built ProPic2, which went on parallel port.
    Now that I no longer have the parallel port, I bought a K150 on the internet. This mounts on USB.
    1) I write the code in MicroCode
    2) the MicroCode settings are these
    3) I take the .Hex file
    4) I load the firmware for download on this program:
    5) I mount the chip on the K150
    6) I program
    7) At the end I reassemble my chip in the BreadBoard
    and go ON
    Apr 2020
    Excellent, I tried. But it behaves the same way !!
    I noticed that by entering your firmware the fuses are set automatically as I manually set them.
    And that's OK.
    But the behavior seems identical to that compiled by me. After an initial click, the relay goes ON even when the temperature is lower than 30 ° and when it exceeds 30 ° nothing happens.
    This compiled HEX test your PORTA.6 (pin 15) on your PIC if is it wired right.
    It switch ON and OFF the relay five times, on LCD write: Rele ON if activate the pin
    and Rele OFF when deactivate the pin.
    If this perform As I wrote then the rele is wired OK and works. Then the fault must be elsewhere.
    Then we go troubleshoot further more.
    Apr 2020
    [QUOTE = louislouis; 145045] Questo HEX compilato verifica il tuo PORTA.6 (pin 15) sul PIC se è cablato correttamente.
    Accedere e spendere il relè cinque volte, sul display LCD scrive: Rele ON se si attiva il pin
    e Rele OFF quando si disattiva il pin.
    Se questo funziona Come ho scritto, il rele è cablato OK e funziona. Quindi la colpa deve essere altrove.
    Quindi andremo a risolvere i problemi. [/ QUOTE]
    Ti confermo.
    Il relè attiva e disattiva 5 volte l'
    ultimo passaggio, spegne il relè, pulisce lo schermo e non appena lo schermo mostra le temperature, il relè viene attivato.
    A quel punto non succede più nulla, anche quando la temperatura ambiente supera i 30 °
    OK, please program this HEX and tell what number shown on display. Then warm up the sensor with fingers or soldering iron. The numbers should be arround 600 for 30degC and 700 for 35degC and so on.
    This test the ADC reading on your PIC.
  1. How to compare two temperatures
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2012, 09:07
  2. how to hserin compare with known value?
    By aa222k in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2010, 18:48
  3. Is there a faster way to compare?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 19:48
  4. how to compare data
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 22:30
  5. Compare Data
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 20:40
Members who have read this thread : 7
