Touch switch ON/OFF
Results 1 to 6 of 6
    Default Re: Touch switch ON/OFF
    towlerg: that's how it works. First touch turns ON, second touch turns OFF.
    Richard: so what was wrong with the first draft ?
    basically nothing. First I didn't proper understand how the code works and wrong output handling. Then I hooked up serial converter and send out the results. After understanding the principe it's easy to modify it to my needs.
    I needed this for switching an extraction fan as I wrote before, under my stereoscopic soldering microscope only with touching with soldering iron tip, or finger. It's more comfortable then struggling with rocker (main) switch on microscope body.
    If anyone interested how it looks and works, here a short video:
    Oct 2009
    Utah, USA
    If you want a super easy stand alone touch switch I highly recommend these...
    https://www.amazon.com/TTP223-Capaci...194533&sr=8-27
    They can be configured either momentary or latching and either active HI or LO.
    I have used them and they work very well.
    dwight
    Dwight
  1. Replies: 0
    Last Post: - 26th January 2015, 06:18
  2. Toggle switch (latching switch) state
    By craigwb in forum General
    Last Post: - 6th November 2011, 15:18
  3. Replies: 6
    Last Post: - 9th January 2011, 16:26
  4. Touch Sensitive Switch
    By BobP in forum General
    Last Post: - 23rd August 2007, 23:27
  5. touch switch dimmer
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 12:25
