Some example of how to use the MAX30100 in PBP?
Results 1 to 6 of 6
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Default Re: Some example of how to use the MAX30100 in PBP?
    ING:
    Good morning and thanks for responding ... In the midst of this crisis, your recommendation is complex. We specifically need to add that sensor to our project.
    ESP:
    Buen día y gracias por responder... En medio de esta crisis, es compleja tu recomendación. Específicamente necesitamos sumar ese sensor a nuestro proyecto.
    I though you needed a stand alone device.
    But if you need to make other machine is different matter.
    The data sheet has all the info and I had a look. There are registers that need to be set and then others to read back. The chip even controls the current of the two LED's. Is not that simple I am afraid.
    Aug 2012
    exactly that's it; I did not find any topic as a guide, therefore I assume it is complex.
    regards
    a quick look at an arduino lib for your chip reveals a fair bit of fp math and 32 bit variables too, all this done at 100hz sample rate.
    its a tall order for those low spec pic chips mentioned
    https://github.com/xcoder123/MAX30100
  1. Replies: 2
    Last Post: - 12th November 2014, 08:57
  2. PBP File Extension: .BAS vs .PBP
    By nedtron in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 06:48
