Remote Control I/R TSOP4138 Help
Results 1 to 4 of 4
    Default Re: Remote Control I/R TSOP4138 Help
    Andy, I would place a 10uF ceramic cap across the processor after the 100 Ohm resistor. I would also replace the 100 Ohm with a 10 Ohm. I have to ask what are you doing with the remaining pins on the processor? Also, what other circuits are you powering from the LDO? I am assuming the regulator is somewhere on the left of the schematic?
    EN82fn
    May 2012
    Merseyside, UK
    A Little bit more :-
    The unused pins are set as outputs Using TRISA=00000000 and TRISB=00010000 (RB3 is the i/p for the InfraRed)
    Only other cct is a clock DS1307 on RB1 and RB2 (SDA and SCL)
    LDO is LM2931
    Andy
    Andy, What do you mean by " is being spiked by mains EMI and causing issues."? Please explain... What is it doing wrong?
    EN82fn
  1. Remote control help
    By paulthegulll in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2010, 10:01
  2. Help with remote control
    By Clodoaldo in forum mel PIC BASIC Pro
    Last Post: - 8th July 2009, 00:24
  3. IR/RF Remote Control
    By jhorsburgh in forum General
    Last Post: - 6th February 2008, 03:23
  4. RF Remote control
    By eralp in forum General
    Last Post: - 11th January 2007, 00:15
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 16:13
