Yes, it works fine without it until it doesn't.it turned out that the time taken to clear/set cs pin and the impost of two extra pins was as waste of resources an an unnecessary
complication. it works fine with out it
The SPI slave counts 8 clocks on SCLK in order to set BF to let you know you have a byte.
When the slave uses the SS input, that bit counter is reset when SS goes high. That keeps
you in sync with the master.
Without it, if there's ever a single glitch on the SCLK line the bit counter will be wrong and you can never resync master -> slave.
That also means that when you first power up, depending on who gets initialized first, there's a chance that the slave could see a transition on SCLK and you never get sync'd to begin with.
@Sheldon - I reread your requirements and I have to admit I'm not sure what you're trying to do.
If I read the comments correct you say that the slave isn't going to use data in. What would be the purpose of the slave?
