DT Interrupts and HSERIN / HSEROUT
Results 1 to 4 of 4
    Miami, Florida USA
    Default DT Interrupts and HSERIN / HSEROUT
    I'm using the DT USB Interrupts in the link below. In the same program, I'm using a few HSERIN and HSEROUT commands. I know that these two things don't like each other. However, since this DT USB interrupt happens so quickly, I thought that it might not affect the HSERIN and HSEROUT commands at all. Should I disable the interrupts before using these commands?
    http://www.picbasic.co.uk/forum/show...4292#post94292
    Anonymous
    Default Re: DT Interrupts and HSERIN / HSEROUT
    seems no one else wants to comment
    reading the thread you linked it seems that using hserin/out rather than serin/out was the solution for serial comms when a usb int was used.
    if you disable usb int for more than 10mS your usb "connection" will be lost
    i have no issues using hserout or spi comms with the cdc usb function with the usb int
    Miami, Florida USA
    Richard, thanks for the reply. I was concerned that the interrupt might interfere with the HSERIN and HSEROUT commands.
    Anonymous
    hserout could never be affected by interrupts in any normal sort of asynchronous use
    hserin will not be affected by interrupts in any normal sort of asynchronous use provided the isr does not take so long as to cause a buffer overrun
  1. Help understanding HSERIN/HSEROUT
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2021, 07:47
  2. HSERIN and HSEROUT Pins
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2014, 21:08
  3. HSERIN and HSEROUT problems
    By amindzo in forum Serial
    Last Post: - 6th September 2006, 21:11
  4. Problems with HSERIN HSEROUT
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 20th September 2005, 17:24
  5. Hserin/hserout ?
    By Scott in forum General
    Last Post: - 27th April 2005, 23:46
