Victron , VE.Direct
Results 1 to 6 of 6
    Default Re: Victron , VE.Direct
    turned out UDP was a poor choice, there is no guarantee UDP packets will be delivered at all or even arrive in order sent.
    i changed over to an espwebserver model and used http GET/POST requests which worked ok but on a busy network or with poor wifi reception and having multiple clients made synchronizing victron device responses with the web requests very clumsy. ESPAsyncWebServer allows for a better solution has worked nicely, so far.
    a WebSocket Server will probably be the ultimate solution when i find time to learn another trick.
    best place to start is the arduino ESPAsyncWebServer demo
    i took some ideas from this, but used littlefs rather than the deprecated spiffs
    to really get anywhere you want an understanding of c++ , html and one of the browser scripting languages like js or php
    this can answer most questions
    https://www.w3schools.com/
    my current educational project is a weather station webserver;
    pic16f18326 - 32k fram - bme280 - esp02s
    would love to find a socket to fit TYWE2S ESP8285 Module
    i was using the m3 but the price/availability ratio has soured
    Thanks Richard.
    Amazing things, too much knowledge...
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 21:32
  2. WIFI Direct Module Recommendation
    By ssnickson in forum Ethernet
    Last Post: - 24th October 2013, 13:50
  3. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 18:27
  4. Direct replacement for 16F688
    Last Post: - 7th September 2006, 01:20
  5. max232 vs direct serial
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2005, 01:07
