pass pic basic pro pic from pic 16f877a to pic 16f887
Results 1 to 9 of 9
    Thumbs up Re: pass pic basic pro pic from pic 16f877a to pic 16f887
    hello I sent you the following link of the video of the simulation in proteus of the symmetric source with pic 16f877a, and you will see that the values of the voltages and negative flash a lot and do not remain fixed.
    I know that the replacement of pic 16f877a is pic 16f887, and I want this same code to work with pic 16f887.
    In addition, this was a work that I presented at the university in my digital electronic subject and obtained a 4.0 as final work.
    Here I leave the link
    https://drive.google.com/file/d/1jlS...ew?usp=sharing
    And thanks again
    José
    Default Re: pass pic basic pro pic from pic 16f877a to pic 16f887
    in the simulation in proteus on the 20x4 display in the positive and negative voltage blink a lot and they are not fixed, and I have not been able to correct this fault
    thats not even a close description of what i see in the vid
    i see an
    incompletely described pgm with no config settings
    performing an undescribed task
    in an unspecified circuit
    that when simulated in an unspecified environment
    performs not as hoped for(what ever that expectation is)
    who would have thought it ?
  1. Trying to integrate Visual Basic with PIC 16f877a
    By vtolentino in forum General
    Last Post: - 9th March 2011, 09:22
  2. serial interface pic 18f452 using pic basic pro
    By syed ahmed in forum Serial
    Last Post: - 16th May 2010, 05:46
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 00:52
  4. Replies: 5
    Last Post: - 17th January 2006, 19:26
  5. help pic basic pro
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 29th September 2003, 00:55
