Snap programmer
Results 1 to 13 of 13
Thread: Snap programmer
    Default Snap programmer
    I picked up one of these low cost programmers at the current 50% discount offer price from microchipDIRECT making the part extremely cheap. Now trying to get it to work and could use some help.
    I have Microchip's dedicated programming software installed, i.e. MPLAB X IPE v5.00. The Snap is plugged into a USB and the green Active led is on. However, when attempting to select a programming device from the software's Tools screen there are no choices listed on the drop menu. Why is this?
    Further examining the Tools > Plugins tab I see 27 Installed and Active devices, including one called "snap", but again, nothing come up on the Select Tool drop down.
    OK
    Default Re: Snap programmer
    It sounds like you're trying a "back door" approach. First, what IDE are you using? MicroCode Studio? MPLABX?
    From MicroCode Studio you should have the option of adding a Programmer to the list. Last option, use MPLABX IPE to burn the Hex file to your PIC.
    The Snap is just another programmer; like PICKit3, U2, etc. It needs to be added to your "tool box" just as any other programmer.
    What programmer have you successfully used in the past? How did you incorporate it into the IDE you use (PBP uses MicroCode Studio)?
    I don't have a Snap-programmer so I don't have any personal experience but I would try to update MPLAB X IPE since 5.0 is fairly old. Current version is 5.30 and the release notes mentions some USB-driver stuff at v5.05.
    IMO you're doing it 100% correct, get it working with IPE as it IS the official software tool for the programmer. Get it woring from within IPE first.
    Good advice, but having got it working with IPE why bother with MPLabx? From memory theres a CLI (or similar) within IPE to allow programming from PicBasic IDE (ala PK2 et al)
    George
    No reason, but IPE comes as part of the MPLAB X download/installation - I don't think you CAN download IPE by itself...
    Yes, and I'd bet that under the hood the IPE application calls upon that same CLI when programming so once the Snap is working from within the IPE application setting it up in MicroCodeStudio shouldn't be too hard.
    Yes, I now have MPLAB X IPE version 5.30 installed and there is some progress. The Snap programmer is now recognized and my connected PIC device is correctly identified. However, I have more work to do as the basic programming functions are not behaving as expected, i.e. Read, Erase, Program
    Yes, of course I would like to get the Snap programmer to work within MicroCodeStudio . What is a CLI?
  1. Replies: 0
    Last Post: - 6th December 2016, 10:28
  2. Programmer Help
    By jetpr in forum General
    Last Post: - 21st January 2009, 23:43
  3. programmer
    By jcleaver in forum General
    Last Post: - 6th March 2007, 00:15
  4. What Programmer are you using?
    Last Post: - 27th February 2005, 21:16
  5. New Programmer. Which one????
    By rastan in forum General
    Last Post: - 26th January 2005, 11:55
