Pickit 3 failed to program
Results 1 to 22 of 22
    OK
    Default Re: Pickit 3 failed to program
    In a previous post the question was posed, where to buy? I searched Microchip's site for PICKit3 and it appears they have discontinued selling it. There are probably many in inventory at DigiKey and other vendors. Their flagship programmer is now the PICKit4:
    https://www.microchip.com/developmen...tails/PG164140
    Their cost leader is the Snap programmer costing around $15 US.
    https://www.microchip.com/developmen...tails/PG164100
    Disregard post above about mclr.
    What I need to know is this --
    I've always had mclr tied to Vdd through a 4.7K with my earlier stuff but now with this 16F88 or 1847 I see the mclr is also porta.5 which has me thoroughly confused about the importance of mclr in the first place.
    Right now I have all pins on porta as outputs.
    ?? what should I be doing? I can lose the porta.5 as an output if need be.
    sorry about all this mindless gibber jabber. ran into this which clarifies much in plain english --
    https://www.theengineeringprojects.c...-pic16f88.html
    and wow, pretty nice site I've never seen before. !
    OK
    Early PIC chips had a dedicated RESET pin; MCLR. Later they allowed that pin to also work as a generic digital input, giving it a name (like RE3). I am not aware of ANY PIC that allows the MCLR pin to be configured as an output. As a caveat, I do know of someone that was able to finagle the MCLR pin to act as a very low current output using the Weak Pull-Up function by turning it on and off.
    Most "modern" PIC devices allow MCLR to be turned off by setting the appropriate bit in config fuses. This pis should be used as an absolute last resort as loads will potentially upset ICSP.
    George
  1. PICKIT 2 verification failed at memory address 0x0000
    By tarekmdimagh in forum mel PIC BASIC
    Last Post: - 11th October 2021, 12:45
  2. Program 3 PICs using one PICKIT 3. Possible?
    By BobEdge in forum General
    Last Post: - 3rd July 2015, 17:20
  3. First try at DT_INT's, I failed! help please!
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2012, 23:07
  4. Failed programmer?
    Last Post: - 24th December 2011, 20:36
  5. Debug Failed
    By firdano in forum General
    Last Post: - 10th February 2011, 16:08
