40466 LCD help
Results 1 to 4 of 4
Thread: 40466 LCD help
    Jun 2008
    Varese , Italy
    Default 40466 LCD help
    Hi to all in this forum,
    I have to interface 40466 (40 chars X 4 lines) LCD with my PIC.
    Is there any pic basic program to take as example please ?
    Thanks for any help .
    regards,
    Ambro
    Default Re: 40466 LCD help
    As far as I can see from a simple Google search it's compatible with the HD44780 controller so it should work fine with LCDOUT. But, since it's 4 lines by 40 characters it uses TWO controllers so it needs to TWO separate Enable-lines, something LCDOUT doesn't support directly.
    You could solve that by externally (to the PIC and controlled by the PIC) gate the enable line to either input on the LCD module.
    Sep 2009
    Maybe this will help
    2LCD.pdf
    Jun 2008
    Varese , Italy
    Thanks to everybody for the assistance and for the sample code.
    It is working very well now.
    regards
    Ambro
  1. Using a parallel LCD(44780 based) as a serial LCD
    By mikejp56 in forum mel PIC BASIC Pro
    Last Post: - 30th October 2015, 02:56
  2. Replies: 36
    Last Post: - 14th March 2011, 19:38
  3. Replies: 2
    Last Post: - 5th November 2009, 18:07
  4. LCD and PIC18F2685 - Weird LCD behavior
    By Castor in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 10:55
  5. to convert LCD // hd 44780 --> serial LCD
    By in forum mel PIC BASIC Pro
    Last Post: - 15th March 2003, 13:37
