well, i tested the first program and doestn works, then I use a LCD (16X2) for view the variable in the Reciever, the lcd show me the number and show me how works my program and i can view that my program is wrong because the data is send time and time again, and before a while the data changes. I mean first put p.e.: 0,0,0,0,0,3,3,3,0,0,0,0 during the switch is off an suposed the lcd put only zeros. and "viceversa"
Then i try to fix the problem but now i doesnt pass anything, i cant recieve or i cant transmitt, i testes the pics and works perfectly, I thought that modules RF had been disturbed, And I connected pics directly and even so it does not pass anything, then I believe that it is my program and at this point already my mind is blocked some help?
here the two codes: (when it worked )
transmitter code:'TX CODIGO TRANSMISOR
INCLUDE "modedefs.bas"
TRISA=6
DATOUT VAR PORTA.0
ONN VAR PORTA.1
OF1 VAR PORTA.2
C VAR BYTE
TX:
IF OF1=1 THEN
C=2
IF ONN=1 THEN
C=5
IF C=2 THEN
SEROUT DATOUT,N1200,[0]
IF C=5 THEN
SEROUT DATOUT,N1200,[7]
GOTO TX
reciever code:'RX CODIGO RECEPTOR
TRISB=1
DATAIN VAR PORTB.0
LEDVER VAR PORTB.1
DATO VAR WORDS
RX:
SERIN DATAIN,N1200,DATO
IF DATO=0 THEN
LOW LEDVER
IF DATO=7 THEN
HIGH LEDVER
goto rx
