Even it could be much than what you think, can you try that one and post resukt
Oldata var byte
Dato var byte
dato=0
oldata=1
rx:
serin datin, N2400,[dato]
if dato != Oldata then
if dato =5 then
high led
oldata-dato
if dato=8 then
low led
oldata=dato
But you may/must need a synchro data, then receive the function you want to do. Lookj for the WAIT modifier.
A common protocol is Manchester, do a search within this forum you'll find the theory. But as you want to receive only 1 or few bytes, send some preamble data (like $aa, $55), then send a Synchro by, then your data). The receiver must wait the synchro, then get the data.
