16F88 -- weird stuff Ansel?
Results 1 to 6 of 6
    Default Re: 16F88 -- weird stuff Ansel?
    yeah, I think the adcon1 addition was my imagination. still acting up. what I'm trying to do is simple look at the data output from an infrared receiver on an input pin (with a pullup) and check for a low. works fine on a breadboard (just doing that with a few lines of code in a loop) but when I try to implement it in some code which has a lot going on, it's haphazard. I've tried using a for next loop so it stays on the input pin, checking a thousand times and even tried a goto where it loops for a few seconds using a counter. (a few seconds would be more than enough to "catch" the pin going low). tried a voltage divider on the pin trying to push it lower to ground, etc. not having much luck.
    But I'll probably figure out after I post this --as always
    Michael I only needed to use the 'F88 for 1 project. Here is my header. I never had any trouble with the inputs or outputs.
    OSCCON = $60 'set int osc to 4mhz
    ANSEL = 0 ANALOG INPUTS NONE
    ADCON0 = 0 'AD MODULE OFF & CONSUMES NO CURRENT
    CMCON = 7 'COMPARATORS OFF (DEFAULT ON POR)
    OK
    If that doesn't work, post your entire code, including your CONFIGuration bits. Use [ CODE] and [/CODE] (without the spaces) to compartmentalize your code in the forum posting.
  1. CANBUS Stuff
    Last Post: - 10th July 2017, 16:46
  2. ANSEL command
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 9th January 2009, 16:33
  3. 18F25K20 & ANSEL = Error
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 17th December 2008, 03:36
  4. The green stuff on a PCB
    Last Post: - 16th April 2008, 13:48
  5. please help me Pwm Timing, RC Stuff
    By eddy in forum mel PIC BASIC
    Last Post: - 15th August 2007, 05:55
