jumping out of a gosub reminder
Results 1 to 18 of 18
    OK
    Default Re: jumping out of a gosub reminder
    Don't use both. What was printed in the above post will GOTO a new address, then erase the RETURN address. This will generate a Stack Underflow condition and the PIC will "exhibit unpredictable behavior". Just use GOTO and leave the Stack alone.
    Sep 2009
    But if I understand correctly he want to goto and never return.
    So you need to pop stack to prevent overflow.
    OK
    Then yes, POP the Stack. Not sure when such an approach might be considered good programming practice, though.
    using goto to control program flow = spaghetti code [hard to unravel ,hard to modify ]
    spaghetti code with stack popping to undo dead subs ?
    franken code ? [as in Frankenstein ]
    you would need good comments with a flow diagram and a state diagram at hand to unravel it
    Sep 2009
    franken code ?
    Not necessarlly, Lot of hi level programing language have this already implemented. eg in .net: On Error GoTo, Try, catch, etc...
    Same could be done for HW. If something external happened then you need unconditionally goto something, and start program from known place.
    It is not easy to implement, by any means. But it could very useful.
    What longpole001 have exactly on his mind, I can't tell...
    Aug 2003
    You could count your gosub nesting level in another variable.
    Increment for every gosub, and decrement for every return.
    You don’t know about PBP's own gosubs, but they are supposed to be the compiler’s problem, and aren’t your responsibility.
    So you would know if the value wasn’t zero when you thought it should be.
    Sep 2009
    When compiler gosub, it will always return. Unless you use ISR to modify stack, which I wouldn't recommend.
    hmm, in python at least a sub with a "try" still returns , even if the processing aborts and executes an "try" error routine.
    i see no goto or stack popping going on.
    a couple of python subs with try
    def process_d(tname,q):    while exitflg==0:
            dx=ser.readline()
            try :
                rt='s'
                ff= string.rstrip(dx)
                int(ff,16)   ##non hex chr will cause ValueError
                if dx[0]=='A':
                     rt='w'
                #print dx
                ts=str(datetime.datetime.now())[:19]
                r_x=[ts,dx,rt]
                queueLock.acquire()
                q.put(r_x)
                queueLock.release()
            except ValueError:
                    #print dx
                    dx=[]
    def bag_reading ():
        global readings
        bag_data_time =datetime.datetime.now()
        if len(readings)>0:
           try:
               conn=sqlite3.connect('/media/CORSAIR/wh2.db')
               curs=conn.cursor()
               curs.executemany("INSERT INTO log values((?),(?),(?),(?))", (readings))
               # commit the changes
               conn.commit()
               conn.close()
               print 'write ',len(readings),'  ',readings[-1][0]
               readings=[]
               bag_data_time += datetime.timedelta(minutes=5)
           except sqlite3.OperationalError as err :
               print 'db busy',err
               bag_data_time += datetime.timedelta(minutes=1)
        return   bag_data_time
  1. programming jumping game
    By bokken in forum mel PIC BASIC Pro
    Last Post: - 17th February 2012, 06:40
  2. jumping out of subroutine with goto
    By helloo in forum General
    Last Post: - 3rd January 2012, 10:37
  3. OWIN not jumping to label
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 15:30
  4. A reminder for all Forum Users
    Last Post: - 6th December 2008, 18:56
  5. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 21:24
