jumping out of a gosub reminder
Results 1 to 18 of 18
    Feb 2012
    PERTH AUSTRALIA
    Default Re: jumping out of a gosub reminder
    thanks mike
    i am going though this code slowly to find any goto's that have found their way into sub's , fixed about 10 or so that if the error condition happend wold have acted on the goto , and left the stack with the address sitting on there from the gosub
    OK
    I commonly use GOTO to jump from one Sub to another when there is nothing left to do in the first Sub. This keeps the Stack from building up, and reduces execution time. Working with the Nextion TFT screens, sending UART commands must terminate with $FF $FF $FF, which I often add in a subroutine. Since that is the last part of the operation, I GOTO FfFfFf: from the last part of the Send_Data: routine, then RETURN from FfFfFf:. It saves a couple jumps, which may involve ASM BANKSELs.
    Know that you are doing it intentionally, know where your Stack is pointing so you know where you ultimately RETURN to, and it can work to your advantage.
    Sep 2009
    I had similar ideas, but give up on them. I use something like this:
    Gosub xx : If err=1 then goto yy
    XX:
    if something to triger going to err sub then
    err=1 ' goto in different sub after retun
    err=0 ' return and continue normally
    But if you must have gosub, without return, you can look up in datasheet of PIC, POP command. It should pop up stack, and free one space.
    Quote Originally Posted by Datasheet
    The TOS value is pulled off the return
    stack and is discarded. The TOS value
    then becomes the previous value that
    was pushed onto the return stack.
    This instruction is provided to enable
    the user to properly manage the return
    stack to incorporate a software stack
    If I understand POP and PUSH commands, you could do something like this
    If err=1 THEN
    @ POP
    GOTO ErrHandler
    OK
    Don't use both. What was printed in the above post will GOTO a new address, then erase the RETURN address. This will generate a Stack Underflow condition and the PIC will "exhibit unpredictable behavior". Just use GOTO and leave the Stack alone.
    Sep 2009
    But if I understand correctly he want to goto and never return.
    So you need to pop stack to prevent overflow.
    OK
    Then yes, POP the Stack. Not sure when such an approach might be considered good programming practice, though.
    using goto to control program flow = spaghetti code [hard to unravel ,hard to modify ]
    spaghetti code with stack popping to undo dead subs ?
    franken code ? [as in Frankenstein ]
    you would need good comments with a flow diagram and a state diagram at hand to unravel it
  1. programming jumping game
    By bokken in forum mel PIC BASIC Pro
    Last Post: - 17th February 2012, 06:40
  2. jumping out of subroutine with goto
    By helloo in forum General
    Last Post: - 3rd January 2012, 10:37
  3. OWIN not jumping to label
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 15:30
  4. A reminder for all Forum Users
    Last Post: - 6th December 2008, 18:56
  5. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 21:24
