jumping out of a gosub reminder
Results 1 to 18 of 18
    Feb 2012
    PERTH AUSTRALIA
    Default jumping out of a gosub reminder
    hi guys ,
    i am reviewing some old code and updating stucture
    I have a need to do a gosub that has a number of program error checks in it
    the gosub is called from many places in code to check if the fuction is allowed depending on the hardware status which is read in the error check sub
    if no errors are found with the hardware test groups selected in the error check routine then returns to the called section
    How ever if it finds an error then it has a direct goto to the service subs and commands branch off to deal with the required error condition , never returning to the orginal routine
    this then breaks out of the orginal "return" to calling sub
    it not great to do but i can see any way to avoid this , in the structure , and ii know after gosub , a return not done can cause issues
    i can avoid the " return " by putting in a series ofg flag so it knows where it was orginally called from but that not a really practical and like to avoid
    what i am i forgetting or better way to aproach this
    Default Re: jumping out of a gosub reminder
    There's no real problem to use GOTO (or nested GOSUBs for that matter) from a subroutine to which you've jumped with GOSUB as long as you eventually end up at a "matching" RETURN but you CAN NOT allow the call stack to simply grow because eventually the thing will crash. If the condition you describe happens rarely you might not see the effects of it until after a (very) long time but trust me, sooner or later it will crash.
    Don't missunderstand, there can be one GOSUB and twenty RETURN statements in a program, or the other way around, no problems but you can not keep pusing return addresses on the call stack without eventually taking them off.
    Instead of that direct goto you mention, why can't you do that as a subroutine?
    Feb 2012
    PERTH AUSTRALIA
    "Don't missunderstand, there can be one GOSUB and twenty RETURN statements in a program, or the other way around, no problems but you can not keep pusing return addresses on the call stack without eventually taking them off."
    i not seen it crash , but the code did have several goto's to a few other subroutines
    most old subs in this code had a error checking of "status test" , to do would be called from many places in the code , some times within several subroutines deep before the error checking routine was called
    then if the error check was positive in the routine it would then do a goto another subroutine to a menu and the option it would then show for the error never to return to orginating sub
    so from this it would mean the deeper in of other subroutines the error check routine was called would be left on the stack as far as i can see ???
    not a good , but never saw a a crash , but maybe that error did not occur perhaps , but seems like its not a thing to be done -
    i am reviweing to so that error subs are a goto from the outset , but this then requires a return location from each differnat location its called from , and the more error checkdone in the subrouint the more options of goto creates , but this is really messy stuff
    what i would like is the ability to have my return and eat it too , lol , but cant see how that would work as clearing the last "return" address , still leaves all the other return address that may have been stacked prior to the sub that had the goto in it , too bad i cant request a fluch of the stack of the now un need returns - but that just bad programing
    just have to redo all the error checking so that is one level or returns to the calling routine and returns i think
    OK
    Here is a simple exercise to review the Stack:
    10:  Main:
    20:  DO
    30:   IF PORTB.1 = 1 THEN
    40:      GOSUB CheckIn
    '  Stack Contains 40
    50:    ENDIF
    60:  LOOP
    70:  CheckIn:
    80:    IF PORTB.2 = 1 THEN
    90:      GOTO Verify
    ' Stack Still Contains 40
    100:  ENDIF
    110:  RETURN
    120:  Verify:
    130:    IF PORTB.1 = 1 THEN
    140:      RETURN
    '  This RETURN jumps to the address in the Stack + 1 (address), so the point of RETURN = 50
    150:    ELSEIF PORTB.2 = 1 THEN
    160:      GOTO NameCalling
    170:    ENDIF
    180:  RETURN
    Feb 2012
    PERTH AUSTRALIA
    thanks mike
    i am going though this code slowly to find any goto's that have found their way into sub's , fixed about 10 or so that if the error condition happend wold have acted on the goto , and left the stack with the address sitting on there from the gosub
    OK
    I commonly use GOTO to jump from one Sub to another when there is nothing left to do in the first Sub. This keeps the Stack from building up, and reduces execution time. Working with the Nextion TFT screens, sending UART commands must terminate with $FF $FF $FF, which I often add in a subroutine. Since that is the last part of the operation, I GOTO FfFfFf: from the last part of the Send_Data: routine, then RETURN from FfFfFf:. It saves a couple jumps, which may involve ASM BANKSELs.
    Know that you are doing it intentionally, know where your Stack is pointing so you know where you ultimately RETURN to, and it can work to your advantage.
    Sep 2009
    I had similar ideas, but give up on them. I use something like this:
    Gosub xx : If err=1 then goto yy
    XX:
    if something to triger going to err sub then
    err=1 ' goto in different sub after retun
    err=0 ' return and continue normally
    But if you must have gosub, without return, you can look up in datasheet of PIC, POP command. It should pop up stack, and free one space.
    Quote Originally Posted by Datasheet
    The TOS value is pulled off the return
    stack and is discarded. The TOS value
    then becomes the previous value that
    was pushed onto the return stack.
    This instruction is provided to enable
    the user to properly manage the return
    stack to incorporate a software stack
    If I understand POP and PUSH commands, you could do something like this
    If err=1 THEN
    @ POP
    GOTO ErrHandler
    OK
    Don't use both. What was printed in the above post will GOTO a new address, then erase the RETURN address. This will generate a Stack Underflow condition and the PIC will "exhibit unpredictable behavior". Just use GOTO and leave the Stack alone.
    Sep 2009
    But if I understand correctly he want to goto and never return.
    So you need to pop stack to prevent overflow.
    OK
    Then yes, POP the Stack. Not sure when such an approach might be considered good programming practice, though.
    using goto to control program flow = spaghetti code [hard to unravel ,hard to modify ]
    spaghetti code with stack popping to undo dead subs ?
    franken code ? [as in Frankenstein ]
    you would need good comments with a flow diagram and a state diagram at hand to unravel it
    Sep 2009
    franken code ?
    Not necessarlly, Lot of hi level programing language have this already implemented. eg in .net: On Error GoTo, Try, catch, etc...
    Same could be done for HW. If something external happened then you need unconditionally goto something, and start program from known place.
    It is not easy to implement, by any means. But it could very useful.
    What longpole001 have exactly on his mind, I can't tell...
    Aug 2003
    You could count your gosub nesting level in another variable.
    Increment for every gosub, and decrement for every return.
    You don’t know about PBP's own gosubs, but they are supposed to be the compiler’s problem, and aren’t your responsibility.
    So you would know if the value wasn’t zero when you thought it should be.
    Sep 2009
    When compiler gosub, it will always return. Unless you use ISR to modify stack, which I wouldn't recommend.
    hmm, in python at least a sub with a "try" still returns , even if the processing aborts and executes an "try" error routine.
    i see no goto or stack popping going on.
    a couple of python subs with try
    def process_d(tname,q):    while exitflg==0:
            dx=ser.readline()
            try :
                rt='s'
                ff= string.rstrip(dx)
                int(ff,16)   ##non hex chr will cause ValueError
                if dx[0]=='A':
                     rt='w'
                #print dx
                ts=str(datetime.datetime.now())[:19]
                r_x=[ts,dx,rt]
                queueLock.acquire()
                q.put(r_x)
                queueLock.release()
            except ValueError:
                    #print dx
                    dx=[]
    def bag_reading ():
        global readings
        bag_data_time =datetime.datetime.now()
        if len(readings)>0:
           try:
               conn=sqlite3.connect('/media/CORSAIR/wh2.db')
               curs=conn.cursor()
               curs.executemany("INSERT INTO log values((?),(?),(?),(?))", (readings))
               # commit the changes
               conn.commit()
               conn.close()
               print 'write ',len(readings),'  ',readings[-1][0]
               readings=[]
               bag_data_time += datetime.timedelta(minutes=5)
           except sqlite3.OperationalError as err :
               print 'db busy',err
               bag_data_time += datetime.timedelta(minutes=1)
        return   bag_data_time
    Feb 2012
    PERTH AUSTRALIA
    XX:
    Pedja idea of this is what i was wanting to for error condiions, but the number of options of error check is about 20 or so
    what i had was several sub routines that specific error checking set flag and byte values given for the error
    each error had a goto another sub routine to show the menu and selection of options to deal with the error found .
    The large error sub was called from many locations, at times 3 or 4 subs deep in code to check the status of hw to see if that option was ok ,
    if it was ok it would return , but if the error was need to be serviced then a direct would goto the " service routines and the options presented " NEVER TO return to the location , it would then run the error service options , a restart was often done after the error was checked / fixed
    what i have done now is not have any goto , just close all the returns back to start , then runs the error service routines - its probably nicer , but a lot more work and code at some points that , just doing a goto and service the error
    Sep 2009
    You could just goto error handler if you found error. Then make just one exit of it, and exit with @ Reset.
    This will reset PIC and clear stack. Same way as if you power off then on.
    Feb 2012
    PERTH AUSTRALIA
    yes some of the options force a reset
  1. programming jumping game
    By bokken in forum mel PIC BASIC Pro
    Last Post: - 17th February 2012, 06:40
  2. jumping out of subroutine with goto
    By helloo in forum General
    Last Post: - 3rd January 2012, 10:37
  3. OWIN not jumping to label
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 15:30
  4. A reminder for all Forum Users
    Last Post: - 6th December 2008, 18:56
  5. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 21:24
