Array error in Hserin
Results 1 to 22 of 22
    Default Re: Array error in Hserin
    Received from Charles this very interesting (and I suppose undocumented) tip:
    array.highbyte[i << 1]=adresh
    array.lowbyte[i << 1]=adresl
    OR
    array.highbyte[i * 2]=adresh
    array.lowbyte[i * 2]=adresl
    instead of
    array.highbyte[i]=adresh
    array.lowbyte[i]=adresl
    Really interesting!
    OK
    Another PBP trick when mixing with ASM is to declare your variables with the addendum SYSTEM:
    Variable VAR BYTE
    @MOVF _Variable, W
    ...becomes:
    Variable VAR BYTE SYSTEM
    @MOVF Variable, W
    UPDATE METHODS
    array var word[2]inx var byte
                       ;UNCOMMENT FOR METHOD 8
    ADRESHi VAR BYTE  ;BANK0  SYSTEM
    ADRESLO VAR BYTE  ; BANK0   SYSTEM
    ;METHOD 0
    word_temp  var word
    ;METHODS 2 AND 3
    array_asbyte var byte ext
    @array_asbyte=_array
    ;ALL METHODS EXCEPT 0 , 1 ,6 ,7 ,8
    'i    var byte
    'i=0
    ;METHOD 4 ,8
    @ MOVE?CW _array , FSR0L    ;  PIC16 ENH CORE
    ;METHOD 5
    '@ MOVE?CW _array , FSR     ;  PIC16 SHITTY OLD CHIP
    ;        CHIP
    for  inx=0 to 1       ;                                                877        1825
    '    word_temp.byte0=adreslo             ;METHOD 0                    30  WORDS  31
    '    word_temp.byte1=adreshi
    '    array[inx]=word_temp
    '    array[inx]=(adreshi<<8)| adreslo    ;METHOD 1                    50  WORDS   48
    '    if !i&1 then                        ;METHOD 2                    57  WORDS   57
    '        array_asbyte[i]=ADRESLO
    '    else
    '        array_asbyte[i]=ADRESHi
    '    endif
    '    i=i+1
    '    array_asbyte[i]=ADRESLO              ;METHOD 3                   30  WORDS    34
    '    i=i+1
    '    i=i+1
    asm                                    ;METHOD 4 PIC16 ENH CORE      na  WORDS    22
      MOVE?BA _ADRESLO
      MOVWI FSR0++
      MOVE?BA _ADRESHi
      MOVWI FSR0++
    'asm                                    ;METHOD 5 PIC16 OLD CHIP      27  WORDS    na
    '  MOVE?BA _ADRESLO
    '  MOVWF INDF
    '  INCF FSR,F
    '  MOVE?BA _ADRESHi
    '  MOVWF INDF
    '  INCF FSR,F
    'ENDASM
    '  array.highbyte[inx*2]=adreshi         ;METHOD 6                    76  WORDS   76
    '  array.lowbyte[inx*2]=adreslo
    '  array.highbyte[inx<<1]=adreshi        ;METHOD 7                    50  WORDS    49
    '  array.lowbyte[inx<<1]=adreslo
    'asm                                    ;METHOD 8 PIC16 ENH CORE      na  WORDS    22
    '  movf ADRESLO,w
    '  MOVWI FSR0++
    '  movf ADRESHi,w
    '  MOVWI FSR0++
    'ENDASM
    next
    stop
    It is very impressive how much room there is for improvements!
  1. Hserin with Array
    By JKaiser in forum Serial
    Last Post: - 11th December 2014, 20:13
  2. Hserin Array Question
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 9th May 2012, 03:39
  3. Error - Fatal Out Of Memory ( With Array)
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 15:36
  4. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 00:07
  5. HSERIN Error
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 13th January 2006, 04:30
