Ability to pay per MCU License.
Results 1 to 12 of 12
    Sep 2009
    Default Re: Ability to pay per MCU License.
    I use TmpB1... TmpW1... TmpL1 etc...
    Passing values to sub cant make nothing for better code efficiently.
    It can make it just look better. Behind curtain, ASM code is same, or worse if compiler move vars for you.
    Aug 2011
    That's not necessarily true... it all depends on how the compiler allocates variables, how much your program uses, and the device.
    If "passed" variables are allocated in access memory vs banked memory the resulting code can be much smaller.
    You just need a good compiler.
    Sep 2009
    Then declare variable in BANKA. And use it.
    I have one of best compilers for pic. It iscalled PicBasic Pro
    And pbp have very good optimization. And wouln't benefit in program size from adding passable variables. It would just be visualy neater code.
    It have usercommand that do exactly that. And I see verry little use of it.
    LOL, why this thread turned into another wishlist? I've asked what is perfectly doable and needs only one executable to be updated....
  1. Need PIC MODBUS RTU code. Will pay.
    By vsingh in forum mel PIC BASIC Pro
    Last Post: - 15th February 2012, 12:04
  2. To Obtain a Driving License in China is Long March
    By CircuitMart in forum Off Topic
    Last Post: - 6th May 2011, 08:47
  3. Replies: 7
    Last Post: - 14th July 2006, 03:21
  4. need help will also pay for help
    By lowina in forum General
    Last Post: - 24th March 2006, 17:44
