Problem with Bootloader + 18F4620
Results 1 to 10 of 10
    I don't have loader files for 16 or 40MHz and the 18F4620 so I can't look at config fuse settings.
    If you open the loader .hex files for 16 or 40MHz with the MeLabs serial programmer, then click on the C to bring up the config screen, what does it show for the MCLR Pin Function?
    If it's set to Reset, you shouldn't have any problem. If it's set to Input Pin, you would need to power cycle to reset.
    If that's not it, give Dave Barker a shout.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Well I just received an email from David Barker with the corrected files that work great. Thanks again David.
  1. 16F876A Bootloader Problem
    By Ashleyr01 in forum mel PIC BASIC Pro
    Last Post: - 15th April 2009, 19:21
  2. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 11:48
  3. Bootloader problem.
    By Peter Oors in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 19:50
  4. Problem With Bootloader And Portb.3
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 31st December 2005, 17:10
  5. 18f4620 bootloader
    By Beavis in forum General
    Last Post: - 26th February 2005, 01:25
