Problem with Bootloader + 18F4620
Results 1 to 10 of 10
    Yes, I did load it with the proper firmware. I tried the one without the PLL and it works fine. However the PLL ones, both the 16 and the 40 will not allow the bootloader to run. The only config fuse that I changed between the 4 MHz and the 4 x 4 MHz was the oscillator type. The rest of the settings I left alone as they worked fine.
    Are you including DEFINE OSC at the start that matches the osc speed defined by the loader firmware?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce, yes. Here are my defines:
    DEFINE  LOADER_USED 1
    DEFINE  OSC 40
    DEFINE  HSER_BAUD 9600
    DEFINE  HSER_CLROERR 1
    DEFINE  HSER_RCSTA 90h
    DEFINE  HSER_TXSTA 20h
    mmm weird. The only thing i can say is to contact David John Barker at Mecanique => [email protected]
    EDIT: i don't have the PLL_18F4620 BTW... probably i miss something
    Assuming your oscillator is working properly, you're using DEFINE OSC to match the loader, and connections are good, it should work fine unless there's a bug in the loader firmware. But I have never had any problems with MCS loader firmware.
    Reset required just means the PC app isn't communicating with the PIC loader. Just out of curiosity, what happens if you comment out all of your HSER defines & all references to HSEROUT/HSERIN?
    Will it boot-load then?
    -Bruce
    tech at rentron.com
    Unhappy Still No Fly
    Well if I program the chip using the ME Labs serial programmer everything works fine and dandy so I can only assume the oscillator is operating properly. Like I said, I've tried the 4 MHz and the bootloader works great, using the 16 or 40 MHz and it's dead in the water.
    I tried removing all references to the USART and it still gave me the same message.
    Quote Originally Posted by Bruce
    I don't have loader files for 16 or 40MHz and the 18F4620 so I can't look at config fuse settings.
    If you open the loader .hex files for 16 or 40MHz with the MeLabs serial programmer, then click on the C to bring up the config screen, what does it show for the MCLR Pin Function?
    If it's set to Reset, you shouldn't have any problem. If it's set to Input Pin, you would need to power cycle to reset.
    If that's not it, give Dave Barker a shout.
    -Bruce
    tech at rentron.com
    Well I just received an email from David Barker with the corrected files that work great. Thanks again David.
  1. 16F876A Bootloader Problem
    By Ashleyr01 in forum mel PIC BASIC Pro
    Last Post: - 15th April 2009, 19:21
  2. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 11:48
  3. Bootloader problem.
    By Peter Oors in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 19:50
  4. Problem With Bootloader And Portb.3
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 31st December 2005, 17:10
  5. 18f4620 bootloader
    By Beavis in forum General
    Last Post: - 26th February 2005, 01:25
